May 16, 2013, 11:23 |
output power of wind turbine
Rep Power: 13 |
hi
I had simulated a wind turbine using fluent and I want to calculate the output power(mechanical power) of it in different wind speeds . I don't know how to evaluate the output power. would you plz help me?? |
May 16, 2013, 20:22 |
Power = Torque*omega.
Assume the axis of the rotor is in the z-direction, and you set the origin at the axis of your rotor, then torque is the z-moment. The omega is angular velocity you specified for the rotor. |
May 17, 2013, 11:03 |
Rep Power: 13 |
tnx a lot dear
it was really useful for me. i have another problem which my moment amounts are negative!!!! my flow comes from y- to y+ i had set my velocity inlet -11 and my rotation direction is +y would you plz help me??? |
May 24, 2013, 15:34 |
#4 | |
Rep Power: 13 |
i have got smaller amount for my simulation using your formula mentioned above. all of them are 100 order smaller: 46kw in stead of 4600kw would you plz help me to find the reason. |
May 28, 2013, 05:26 |
#5 | |
Rep Power: 12 |
i,m using the way that you mentioned in this forum but my results are about 10 times bigger than the exact amounts. i really need help.would you plz guide me??? |
May 28, 2013, 08:17 |
#7 | |
Rep Power: 12 |
my angular velocity is in rpm and i set it in units panel too. where can i change the cp in fluent???? or how can i totally reduce cp ?????? |
May 28, 2013, 08:38 |
#9 | |
Rep Power: 13 |
torque in fluent: 51084019 nm ang velocity:12 rpm |
May 28, 2013, 08:43 |
#10 | |
Rep Power: 12 |
my rated power : 5 MW torque in fluent: 51084019 nm ang velocity:12 rpm |
May 28, 2013, 08:50 |
#12 | |
Rep Power: 12 |
rotor diameter:63m rated wind velocity:11m/s rated ang velocity and my rotational velocity :12rpm |
May 28, 2013, 08:51 |
#13 | |
Rep Power: 12 |
rotor diameter:63m rated wind velocity:11m/s rated and velocity and my rotational velocity :12rpm |
May 28, 2013, 08:56 |
#15 |
Rep Power: 12 |
May 28, 2013, 09:17 |
#16 |
Rep Power: 12 |
May 28, 2013, 09:42 |
#18 | |
Rep Power: 12 |
in addition mass flow rate difference between inlet and outlet is 250 kg/s when the total inlet mass flow is 693639.75 kg/s axial velocity contour in y=0 plan |
May 28, 2013, 13:58 |
#20 | |
Rep Power: 12 |
i had done what you told. please take a look at this photos and check if my solution is converged or not. in this situation the torque is 44944300 |
Compute the power of small wind turbine. | Luolin | FLUENT | 9 | May 27, 2013 14:52 |
shaft power versus RMP curve in wind turbine simulation | zhenduan306 | CFX | 28 | November 8, 2012 10:11 |
FSI - Wind Turbine | AUN | CFX | 13 | August 29, 2012 16:44 |
Wind Power | Frank Grassi | FLUENT | 0 | October 12, 2007 11:20 |
about wind turbine power prediction with cfd | windman | FLUENT | 1 | January 11, 2007 06:41 |
