Simulation the free convection in fluent
Like Tree1Likes
  • 1 Post By ashkan_1984
Old   May 25, 2013, 16:16
Default Simulation the free convection in fluent
ashkan
ashkan_1984 is on a distinguished road
Dear all,
I want to simulate natural free convection in fluent but I cant.I do this thing up to now and I cant reach to answer:
1-In operation condition I give -9.81 in the y part.
2-I give the density of water(my channel is full of water) in businesqe
please help me
ashkan_1984 is offline   Reply With Quote
Old   May 26, 2013, 06:16
Default free
ashkan
I cant understand any thing
macfly likes this.
Old   May 26, 2013, 15:50
alireza
alireza9359300 is on a distinguished road
hi. its steady or unsteady simulation.
alireza9359300 is offline   Reply With Quote
Old   May 27, 2013, 02:38
Default free
ashkan
Unsteady 3D simulation
Old   May 27, 2013, 11:14
alireza
3d+natural+unsteady simulation is out of the power of normal computer.
change your problem into 2d
if you use temperature bc increase its value to see the result sooner
reduce the mesh in your problem to use less memory of your computer
your time must be large to see anything.
Old   May 28, 2013, 07:50
Default free
ashkan
I don't have problem about memory only I can't simulate natural convection.
Old   May 28, 2013, 16:21
alireza
what about time of your simulation?
by small time you cant see any changes in domain of natural sim.
so you must use large time:
by: little time step + large number of time steps + large iteration number in each time step + 3d + natural + small mesh + high order of solving = be sure you will have memory problem of using normal computers.
if you don't have memory problem just you must insert large time for natural simulation to see changes in domain another way is to increase the value of the bc ( if you are using temperature bc ) to have more influence on your fluid.
if I were you
first I simulate it steady after it try to solve it unsteady , cause of for being sure it is true.
if you like . can you send me case & data file of your problem.(little size .
before solving ) alireza9359300@yahoo.com
Old   May 30, 2013, 03:48
Jim Knopf
JimKnopf is on a distinguished road
And don't under relax the enegry equation
JimKnopf is offline   Reply With Quote
Old   May 31, 2013, 17:33
alireza
I think your problem is density (change it to compressible fluid not boussings)
I sent it for you.
Old   June 1, 2013, 03:52
Jim Knopf
He already said he's using Boussinesque ansatz, that should work.
As he is writing about a channel, it sounds to me as if he is trying to solve a Rayleigh-Benard convection type of problem. That always takes a while to start.
To force starting the convective motion one could initialize the field with a smal amount of velocity in the assumed direction of motion.
Anyways, more info is needed.
Greetz
Jim
Chemical Equilibrium Simulation using Fluent enigma ANSYS 2 October 27, 2011 08:02
Free surface simulation Moti ANSYS 0 August 13, 2009 13:41
Fluent simulation over airships Aragon FLUENT 8 March 30, 2009 12:12
Fluent simulation over airships Aragon FLUENT 0 March 27, 2009 12:38
Can Fluent solve free interface problem? xueying FLUENT 3 July 18, 2002 15:29
