Refining Mesh in Fluent?
Like Tree1Likes
  • 1 Post By JimKnopf
Old   May 27, 2013, 14:44
Default Refining Mesh in Fluent?
pyroknife is on a distinguished road
When you guys refine your mesh, do you do it in the program you generated your mesh in or can you do it in Fluent?
pyroknife is offline   Reply With Quote
Old   May 28, 2013, 04:10
Muhammad Aqib Chishty
MAC88 is on a distinguished road
Send a message via Skype™ to MAC88
What do you mean, when?
In which software you are creating the mesh, or you are using your own code?
To validate your CFD results with the available experimental results or numerical data, one has to refine our mesh.
That's why, Grid Independence study has been done.
Best of luck!!!
MAC88 is offline   Reply With Quote
Old   May 28, 2013, 12:21
Best of luck!!!
I'm generating my mesh in ANSYS Workbench and running the simulation in FLUENT. I'm just looking for ways to refine my mesh. Can you refine your mesh in FLUENT or only in the workbench?
Old   May 29, 2013, 09:21
Jim Knopf
JimKnopf is on a distinguished road
You can refine the mesh in Fluent using the adaption tool in the ADAPT menu, it work fairly well, at least for tetra meshes.
If you over did it with the meshing you can also do coarsening of the mesh, or try the conversion to polyhedrals -> found under Mesh.
Greetz
Jim
8cold8hot likes this.
JimKnopf is offline   Reply With Quote
Old   May 29, 2013, 20:20
Cool thanks. Which option in the adapt menu is it?
Old   May 30, 2013, 03:38
Jim Knopf
Except from the last 5 Options they are all for mesh refinement, it depents on what you want.
If you want to create refinement boxes, the Region option is your choise.
[ICEM] Using Surface Mesh from ANSA for Fluent Sim tommymoose ANSYS Meshing & Geometry 15 March 3, 2016 17:29
[snappyHexMesh] No layers in a small gap bobburnquist OpenFOAM Meshing & Mesh Conversion 6 August 26, 2015 09:38
[Gmsh] 2D Mesh Generation Tutorial for GMSH aeroslacker OpenFOAM Meshing & Mesh Conversion 12 January 19, 2012 03:52
[ICEM] Export ICEM mesh to Gambit / Fluent romekr ANSYS Meshing & Geometry 1 November 26, 2011 12:11
Moving mesh in Fluent fivos FLUENT 0 April 2, 2010 09:45
