Gridlines in FLUENT
Old   May 30, 2013, 03:54
Default Gridlines in FLUENT
E
EIvb is on a distinguished road
Hello all.
I was just wondering is there a method or UDF code available that will add gridlines and a scale to contours or animations in FLUENT after calculations have been done?
Thanks
EIvb is offline   Reply With Quote
Old   May 30, 2013, 05:06
ringtail is on a distinguished road
Originally Posted by EIvb View Post
Hello all.
Thanks
Results -> Graphics and Animations -> Contours -> Surfaces
Select all the surfaces and then click the display button.
You may get a contour with gridlines.
ringtail is offline   Reply With Quote
Old   May 30, 2013, 05:14
E
Hello.
Thanks for your response.
I have tried this method to show contours but gridlines are still not showing.
I need the gridlines so I can work out what the maximum distance of a value is.
I am using FLUENT 14 if that makes a difference.
Connecting Fluent benefits and Injection Molding Software Jim87 FLUENT 1 August 6, 2023 16:06
Two questions on Fluent UDF Steven Fluent UDF and Scheme Programming 7 March 23, 2018 03:22
heat transfer with RANS wall function, over a flat plate (validation with fluent) bruce OpenFOAM Running, Solving & CFD 6 January 20, 2017 06:22
Alias problem when starting FLUENT from command line batch_error FLUENT 0 May 24, 2012 08:20
Problems in lauching FLUENT Lourival FLUENT 3 January 16, 2008 16:48
