Boundary conditions for a sail boat on FLUENT
Old   April 10, 2007, 02:41
Default Boundary conditions for a sail boat on FLUENT
Gaylor
Hi everybody!
As we explained in a previous message, we are trying to modelize a sailboat on Fluent.
We insist on the fact that our problem deals with FLUENT and not GAMBIT. We already have modelized the geometry of the boat on Gambit.
But now, we have a big problem with the boundary conditions on FLUENT. We are using the VOF model (air/water), free surface. Our parameters (segregated, unsteady, k-epsylon, 2 inlets, 2 outflows)
Shall we use the Open Channel and how can we do that? We want to use velocity inlet but some people told us to use pressure inlet!! Somebody could explain why and the way of doing this???
Thank you very much.
Old   April 10, 2007, 03:36
Default Re: Boundary conditions for a sail boat on FLUENT
Charles
When using the Open Channel BC you don't need separate air and water inlets and outlets. The reason for selecting pressure inlet is that it allows you to select the Open Channel BC (this is in Fluent 6.2.16 onwards, older versions are more difficult).
Old   April 10, 2007, 03:48
Razvan
First of all, you need Fluent 6.2 or 6.3 to be able to use Open Channel. In both versions, only after activating VOF model, "open channel" will become available in the "Boundary conditions" panel.
If you would read the documentation, you will see that "open channel" needs a "Pressure-inlet - Pressure-outlet" or "Mass-flow-inlet - Pressure-outlet" boundary conditions combination to work. The first is easier to setup, because it only requires the velocity of the air+water flow and the level of the free surface + the level of the bottom (both relative to the reference coordinate system of the grid). It has only a slight disadvantage: it needs a dense enough grid on the boundaries to keep the mass imbalance low.
Also, "open channel" does not require separate inlets or outlets for the two phases. It needs only one inlet boundary (pressure-inlet) and one outlet boundary (pressure-outlet).
And you do not necessarily have to use unsteady formulation, "open channel" works well in steady mode also, the only care you have to take is to seriously underrelax the solution (all underrelaxation factors must be 0.5 or less, momentum 0.2-0.3, volume fraction 0.2) and to use "Body Force Weighted" discretisation method for pressure. It wil take maybe 1500-2000 iterations with first order and about 5000 more with second order to obtain a converged solution.
All the best,
Razvan
Old   April 10, 2007, 08:51
Gaylor
ok thank you very much for your help.
we have done that but we don't manage to patch water. we only have air or only water. Do you have a solution? shall we patch water to 0,5 instead of 1?
our problem is that we manage to do it for the inlet face but we don't manage to expand it to the volume!
thanks regards
Old   April 10, 2007, 09:19
Razvan
To patch the water in the flow volume you need to create a register first. For that you have to go to "Adapt/Region" panel, and "Mark" all cells inside a rectangular region which expands from the free surface position downward. Then type "(rpsetvar 'patch/vof? #t)" in the TUI (without "", of course). This will ensure a smoother initial free surface. Then go to "solve/Initialise/Patch" panel and select "hexahedron-xx" and patch a volume fraction of 1 in it. That's it!
Razvan
Old   June 6, 2013, 12:10
FHydro
flow_CH is on a distinguished road
Originally Posted by Razvan
;140766
Razvan
i want to model a open channel too.
where is "all cells inside a rectangular region which expands from the free surface position downward"? i marked inside the inlet of model for patch, but no cells marked and when i outside the inlet, fluent marked all cells of my model. I think when we define boundary condition of open channel in BC panel, we do not need to patch volume fraction in inlet BC. Am i right?
And i have exactly the "Gayor" problem(we only have air or only water after solve)
i am confused.
flow_CH is offline   Reply With Quote
non reflective boundary conditions for incompresible flow Pascal_doran OpenFOAM Programming & Development 16 August 25, 2015 05:35
Boundary Conditions for aircraft engine in Fluent 6.3 Tareen FLUENT 0 July 20, 2011 00:05
Exporting Fluent boundary conditions for Ansys FEA Cav FLUENT 0 February 22, 2010 11:14
How to set the wind tunnel Boundary conditions in Fluent??? Saima FLUENT 1 April 14, 2009 00:12
Convective Heat Transfer - Heat Exchanger Mark CFX 6 November 15, 2004 15:55
