mesh element number
Old   June 8, 2013, 12:27
Default mesh element number
Grigor Nikolov
Grigor Nikolov is on a distinguished road
Send a message via Skype™ to Grigor Nikolov
Hi everyone
im doing VIM simulation but i need to obtain numbers of some elements in the mesh. The mesh is unstructured and it is made with ICEM CFD. The boundary is wall type with ID=11 and it consist 32 2D wall elements.
PLS help
tnx in advance.
Grigor Nikolov is offline   Reply With Quote
Old   June 15, 2013, 13:51
Default mesh number
Pouria
Pouria is on a distinguished road
Why do not you use ICEM itself to get the mesh element number at each part?
You can select the part there and then go to mesh info to check the number of mesh elements.
Thanks.
Pouria
Pouria is offline   Reply With Quote
Old   June 16, 2013, 04:47
Grigor Nikolov
Tnx for reply.The problem appears after mesh is imported in FLUENT. It seems that there is difference between element numbers in ICEM and element numbers in FLUENT. If someone knows connection between numbers pls help.
Old   June 16, 2013, 08:54
Lefteris
Aeronautics El. K. is on a distinguished road
Maybe going to Mesh --> Reorder --> Domain will solve your problem
Lefteris
Aeronautics El. K. is offline   Reply With Quote
mesh file for flow over a circular cylinder Ardalan Main CFD Forum 7 December 15, 2020 13:06
decomposePar pointfield flying OpenFOAM Running, Solving & CFD 28 December 30, 2013 15:05
[ANSYS Meshing] Defined element number for 2D mesh TomM ANSYS Meshing & Geometry 2 May 11, 2013 12:49
[snappyHexMesh] external flow with snappyHexMesh chelvistero OpenFOAM Meshing & Mesh Conversion 11 January 15, 2010 19:43
