June 8, 2013, 16:51 |
interface not working, bug in fluent?
Rep Power: 14 |
I am working with a sliding mesh to simulate a fan. I am using a mesh interface between the moving zone and the non-moving zone. However, fluid does not appear to be passing through the zone, and the simulation diverges after about 20 iterations. Has anyone seen this before?
I have gotten this to work recently, then I changed the geometry, remeshed, and used the same settings. This time however, no luck. I think this is a bug, but possible I am making a simple mistake. Has anyone seen this before? |
June 8, 2013, 23:38 |
sina
Rep Power: 14 |
Dear Mach zero
what is your boundary condition in inlet and outlet? is divergence on mass balance? Regards |
June 9, 2013, 07:22 |
Rep Power: 12 |
Hi MachZero
you should check interface bc in your mesh generation software. first plz check element size of mesh in two sides of interface. |
sliding interface |
Wind turbine simulation | Saturn | CFX | 58 | July 3, 2020 01:13 |
[ICEM] domain interface in ICEM for fluent | hsn | ANSYS Meshing & Geometry | 24 | November 27, 2012 16:43 |
[DesignModeler] Geometry working in GAMBIT but not FLUENT | CDollarsign | ANSYS Meshing & Geometry | 5 | September 13, 2012 09:29 |
Fluent jobs through pbs | ibnkureshi | FLUENT | 5 | June 9, 2011 13:43 |
Convective Heat Transfer - Heat Exchanger | Mark | CFX | 6 | November 15, 2004 15:55 |
