Reduced domain/ Pressure inlet to velocity inlet
Old   June 26, 2013, 15:02
Default Reduced domain/ Pressure inlet to velocity inlet
victoryv is on a distinguished road
As I wanted to reduce my domain, I performed initial simulations for whole domain and obtained the results/values at certain planes. Then I cut the domain at that planes. I am using density based solver. Earlier the boundary conditions were pressure inlet and pressure outlet. As I wanted to give boundary layer profile at the inlet, I have given velocity inlet boundary condition. AFAIK that velocity inlet BC is not good for density based solver.
1. Is the BC good for density based solver?
2. If not, is there any way to give boundary layer profile at the inlet?
PS: When I use FMG initialization, I was getting NAN.
victoryv is offline   Reply With Quote
Old   June 29, 2013, 14:45
Found a solution. One way you can give boundary layer is by giving PROFILES (located on boundary conditions page). You can generate an ASCII file from previous simulation and then use the generated values. For compressible flow, you need to give total pressure, k , ephsilon/omega.
Velocity inlet within a domain Kevin88 Main CFD Forum 0 December 17, 2012 04:51
ATTENTION! Reliability problems in CFX 5.7 Joseph CFX 14 April 20, 2010 15:45
Pressure jump on supersonic velocity inlet Viktor FLUENT 0 August 9, 2007 00:23
Pressure Inlet yields wrong velocities Ben FLUENT 0 November 21, 2004 01:47
what the result is negatif pressure at inlet chong chee nan FLUENT 0 December 29, 2001 05:13
