Determine "free stream" velocity in incompressible flow analysis |
June 21, 2017, 12:44 |
Tyler Richardson
Rep Power: 8 |
I am simulating an incompressible fluid flowing through a volume, which is irregular in shape. I am looking to find the "free stream" velocity all over the bounded surface of this volume in order to determine heat transfer coefficients through empirical formulae. I was thinking there might be a way to post process local wall shear stress and somehow relate it to the free stream velocity. Or, use some inherent knowledge of the SST wall treatment to back-calculate the boundary layer height and free stream velocity. Does anyone have an idea how this can be done? |
fluent, free stream velocity, heat transfer coefficient, incompressible flow |
Appropriate pressure boundary condition in incompressible flow | lonelywing | OpenFOAM Running, Solving & CFD | 21 | June 6, 2022 09:44 |
How would I write a 2d steady, inviscid, and incompressible flow simulation? | 7he404guy | Main CFD Forum | 5 | January 13, 2017 16:04 |
High velocity in Laminar flow | Manojmech | FLUENT | 0 | November 3, 2016 04:37 |
reversed flow at velocity inlet / mass flow inlet | ib | FLUENT | 1 | March 26, 2007 13:11 |
Can 'shock waves' occur in viscous fluid flows? | diaw | Main CFD Forum | 104 | February 16, 2006 05:44 |
