July 15, 2013, 23:11 |
Understanding Port Flow Results
Reece
Rep Power: 12 |
I have been running some port flow analysis using the ICE system within Fluent and I have gathered results from the tests however I do not fully understand what they are telling me. My setup and results are as follows: Note that is this an exhaust port analysis an so the flow is from cylinder to atmosphere. Now I'm not sure exactly what I should be looking for as far as correct monitors for the result I want. The goal is to compare various port designs to determine which flows the best. Should I be monitoring the port exit plane (the red line) with a Mass Flow Rate monitor? Will that tell me the mass flow rate that the plane is seeing? I am assuming that the outlet mass flow rate is going to be less accurate due to it measuring a volume after my point of interest but I may be incorrect there as well. In some inlet examples I have seen the area weighted average velocity is monitored but I'm not sure this is what I am after. Thanks for any advice. |
starting compressible flow from incompressible flow results | mihaipruna | OpenFOAM Running, Solving & CFD | 2 | December 3, 2012 10:02 |
Flow meter Design | CD adapco Group Marketing | Siemens | 3 | June 21, 2011 08:33 |
on curved channel flow numerical results | yfyap | Main CFD Forum | 4 | February 8, 2011 04:44 |
good Cold Flow Results but problem with Hot Flow | Rams | FLUENT | 1 | June 18, 2006 19:59 |
exemple of simulation results in reactive flow | GACEM_hatem | Phoenics | 0 | June 6, 2001 14:13 |
