Geometry BC's for coupled DPM water spray in closed container of air |
July 24, 2013, 05:10 |
Daniel
Rep Power: 12 |
I'm trying to simulate a full cone injection of water sprayed into a tank of air.
At the moment I'm modelling in 2d axis-symmetric, simple box geometry (400x400mm), all sides are set to Wall BC's except for a small opening in the upper right surface (12mm) which is set to pressure outet. Bottom edge is set to axis BC, and spray injected into bottom left corner. Before any water is injected the air is at rest, and so I have not included any type of inlet for the continuous phase. Is this acceptable for this type of model? Any thoughts, experience or info that you may have would be very helpful. Thank you |
air bubble is disappear increasing time using vof | xujjun | CFX | 9 | June 9, 2009 07:59 |
water injection into air (not spray) | bioman66 | CFX | 1 | July 11, 2006 06:34 |
VOF-compression of air with rising water | yavuz | FLUENT | 0 | November 26, 2005 09:00 |
Separation phenomenon of water, droplet and air | Raymond | CFX | 0 | July 9, 2004 22:59 |
Help!!!problems in air jet into water bath | kim | FLUENT | 4 | June 9, 2003 07:04 |
