Time in fluent
Old   July 31, 2013, 13:24
Default Time in fluent
FHydro
flow_CH is on a distinguished road
Hello
I am new in CFD and fluent.
I am simulating a 2 meters long open channel with water velocity= 4 m/s.
So in field or laboratory, every particle in flow cross into channel after 0.5 second.
I am viewing flow after 0.5 second in fluent (the time that fluent shows), but flow does not yet arrive to outlet. My question is what the mean of time in fluent?
Thanks
flow_CH is offline   Reply With Quote
Old   July 31, 2013, 13:40
rayan
rayan24 is on a distinguished road
Normally if your channel made 2m and your flow velocity equal to 4m/s so after 0.5s each fluid particle traveled the distance (d = 4m / s * 0.5s = 2m), so if the fluid does not reach the outlet after 0.5s I think it's just a problem of viewing no more!! tries to reduce the maximum value of velocity in the scale color. if the probleme is not resolved try to change your "time step" (maybe it is not enough)
rayan24 is offline   Reply With Quote
Old   July 31, 2013, 14:31
FHydro
Thanks for your reply
I do not understand.
The flow is in middle of channel but i have pressure and velocity and etc in downer than that point.
Old   July 31, 2013, 14:50
rayan
By a 3D visualization as you presented we can not draw conclusions .. try to present massqiue fraction and velocity on a one plane (just a plane)that intersects the inlet in the middle and through the channel..(The figures that you show are from a stationary simulation and not unsteady? non)
Old   July 31, 2013, 14:55
FHydro
I will do that but this is unsteady simulation. Why you think this is steady?
Old   July 31, 2013, 15:18
rayan
It's just a feeling .. One question when you started the unsteady simulation, are you part of a solution that already exists? or just after defining your BC you cast the unsteady simulation??
Old   July 31, 2013, 15:28
FHydro
After defining BCs and initialize and patch, i started unsteady simulation. what is your purpose?
Old   July 31, 2013, 16:03
rayan
oouh ..OK, I see where your problem comes!
So to make an unsteady simulation it is necessary to start with a solution already exists (ie its the solution at the initial time (t = 0))
Old   July 31, 2013, 16:13
FHydro
I define velocity and k and epsilon in initial panel. They are in t=0
Old   July 31, 2013, 16:51
rayan
The stationary solution converged well be your initial case (its the solution at t=0)
Old   August 1, 2013, 01:38
FHydro
So you are saying first i should model in steady state then unsteady sate?( in the end of convergence i change steady to unsteady?)
Old   August 1, 2013, 03:28
rayan
Just when you get the convergence of steady state, you save this result then you use this result as the initial case (t=0) (not initialized your converged solution)
Old   August 1, 2013, 17:14
rayan
Is your problem has been solved?
Old   August 2, 2013, 00:54
FHydro
Yes. But i have another problem.
I want to find p/gamma in model but the static pressures(p) are very large. I defined reference pressure location in top of water flow(where the air always exist). It is 101325 pa
Old   August 2, 2013, 02:17
Default Water height
  #15
FHydro
I want to find free surface height (Water height). I am plotting density for air and water(mixture) in a line. But in plot which density in closer to air i should choose for finding water height? (choosing (998) kg/s for water and (......) kg/s for interface between water and air)
Thanks
Old   August 2, 2013, 03:47
rayan
Sorry but I did not understand your question
Old   August 2, 2013, 04:16
FHydro
Just i want to find Water height in channel (from bottom of channel to free surface)
Old   August 2, 2013, 04:19
rayan
Normalement la hauteur d'eau c'est toi qui le définit en se basant sur la visuatlisation de ta simulation!
How to determine time step size and Max. iterations per time step. pratik c FLUENT 46 January 21, 2024 12:21
High Courant Number @ icoFoam Artex85 OpenFOAM Running, Solving & CFD 11 February 16, 2017 13:40
Superlinear speedup in OpenFOAM 13 msrinath80 OpenFOAM Running, Solving & CFD 18 March 3, 2015 05:36
how to obtain time averaged data in Fluent when using SM to simulate mixing tank ziyan7 FLUENT 4 February 14, 2012 02:08
AMG versus ICCG msrinath80 OpenFOAM Running, Solving & CFD 2 November 7, 2006 15:15
