heat expansion of a solid
Old   August 19, 2013, 04:10
Default heat expansion of a solid
Stephan Langenberg
Jim87 is on a distinguished road
In order to check the modulation capability in fluent I need to know if Fluent is useable for simulate heat expansion of solid materials (like metals)
1. Usually Solids expand when getting warm, does Fluent simulate pressures and forces between cells, cellzones and regions which are in contact?
2. Is there the capability to simulate the growth of length for a solid material?
I've done some projects in Fluent, but I couldn't answer this question (from a coworker). Has someone checked the possibility or even establish a simultion including heat expanding?
Jim87 is offline   Reply With Quote
Heat Transfer from Solid to Adjacent Solid and then to Adjacent Fluid dkx209 FLUENT 1 July 18, 2013 09:50
Variable Heat capacity of solid particles prX411 CFX 1 July 12, 2013 09:53
heat conducting solid within a fluid medium? sieginc. STAR-CCM+ 1 February 19, 2012 11:48
heat conducting in a solid domain Rogerio Fernandes Brito CFX 0 March 18, 2008 17:20
CFX4.3 -build analysis form Chie Min CFX 5 July 12, 2001 23:19
