define zones in an imported mesh
Old   August 22, 2013, 16:52
Default define zones in an imported mesh
Stephan Langenberg
Jim87 is on a distinguished road
I have to work on an imported mesh and doesn't find the possibility to work on it and define zones for boundary conditions.
Importing a mesh seems to avoid the working on it. It is not possible to work on the fluent mesh tool (using the workbench). I can only go a step further and open the Ansys Fluent program. The only way I know is uing the adaption function and separating the mesh. This is not the best way (one can't mark walls, only cells), exspecial when I want to define a symmetric wall.
Does someone know an other way of definig walls for boundaries
Jim87 is offline   Reply With Quote
Old   August 23, 2013, 01:48
Paritosh Vasava
vasava will become famous soon enough
You can type 'mesh'+enter in the command window. Again and press enter. This will show you list of commands you can execute to modify mesh or mesh zones.
vasava is offline   Reply With Quote
[snappyHexMesh] No layers in a small gap bobburnquist OpenFOAM Meshing & Mesh Conversion 6 August 26, 2015 09:38
3D Hybrid Mesh Errors DarrenC ANSYS Meshing & Geometry 11 August 5, 2013 06:42
[snappyHexMesh] external flow with snappyHexMesh chelvistero OpenFOAM Meshing & Mesh Conversion 11 January 15, 2010 19:43
choosing faces in CFX with imported WB mesh mactech001 CFX 1 December 7, 2009 02:30
Icemcfd 11: Loss of mesh from surface mesh option? Joe CFX 2 March 26, 2007 18:10
