Total time recommended for a DES
Old   August 31, 2013, 07:05
Default Total time recommended for a DES
siw
Stuart
siw will become famous soon enough
I'm setting up a DES of the flow over a bluff body. Firstly, I have run steady RANS which is the starting condition of the DES. I have run three DES cases for 50 iterations each and at different timesteps to see which one would give CFL numbers below 1 (via Fluent's histogram). The largest timestep to achieved that was 1x10-5s.
Now I can set up the full simulation. But I'm unsure of the total time needed. If I estimate the residence time for a fluid element to pass through the domain at the freestream speed then that time is 0.08s. Let's say I let the simulation run for three times that duration (0.24s), then that would be 24,000 timepoints at the timestep of 1x10-5s.
Is that sensible? What have others done? Because it'll take along time to do this. Can a running average of important output data be set in Fluent?
Thanks
siw is offline   Reply With Quote
How to determine time step size and Max. iterations per time step. pratik c FLUENT 46 January 21, 2024 12:21
Sudden jump in Courant number NJG OpenFOAM Running, Solving & CFD 7 May 15, 2014 13:52
Unstabil Simulation with chtMultiRegionFoam mbay101 OpenFOAM Running, Solving & CFD 13 December 28, 2013 13:12
plot over time fferroni OpenFOAM Post-Processing 7 June 8, 2012 07:56
Total time for simulation Meerkat Main CFD Forum 1 September 5, 2011 07:17
