Rotating turbomachinery: what I am not considering? |
December 19, 2018, 04:56 |
Federico
Rep Power: 9 |
Hello everybody!
I am running simulations for a centrifugal pump using Fluent. RANS, realizable k-epsilon, non equilibrium wall function, PISO solver, transient with mesh motion for the rotating zone. BC are velocity inlet and total pressure outlet. By setting the latter to 0, I am capturing the static pressure through monitoring the area weighted average at the inlet. Adding the dynamic pressure I compare with the experimental data. However, by comparison with the exp. data I see that my head is 2 m lower. As the maximum head for this pump is 14m, a discrepancy of 2m is a huge thing. However, there is something that I am missing and I am screwing up with this. I am not expecting to get the same head, but something closer. By your experience, what do you think I am not considering and that may causes this drop in head? Thanks! |
Issues on the simulation of high-speed compressible flow within turbomachinery | dowlee | OpenFOAM Running, Solving & CFD | 11 | August 6, 2021 06:40 |
Inertial and non-Inertial Reference Frame for Rotating Flows | emreozmen | Main CFD Forum | 0 | January 30, 2017 04:08 |
Car external aerodynamic with wheel spinning issue | hokhay | FloEFD, FloWorks & FloTHERM | 2 | August 18, 2016 04:23 |
Rotating Impeller | Naith | FloEFD, FloWorks & FloTHERM | 22 | November 5, 2012 08:53 |
Vertical Axis Wind Turbine Rotating Domain Problems | TWaung | CFX | 4 | May 1, 2012 03:14 |
