Accuracy in Boundary Layer solution in Fluent
Like Tree2Likes
  • 1 Post By flotus1
  • 1 Post By duri
Old   August 28, 2013, 03:26
Default Accuracy in Boundary Layer solution in Fluent
rameshkumar m bhoraniya
rameshbhoraniya is on a distinguished road
I am trying so solve Axisymmetric boundary layer flow over a cylinder of small radius. the model in 2-D flow is just a rectangular domain with L*R size. the Boundary conditions applied are as under....
Inlet: Uniform velocity U=1 m/s,V=0
No slip bc: at cylinder wall U=0,V=0
Outlet BC: pressure is zero
Free stream bc: U= 1,V=0
The cylinder radius is 10 mm and the normal direction height is about 10 times that of cylinder radius. model size is 1 meter * 100 mm. the computational domain is having enough length in normal to flow direction for free stream boundary condition.
I am getting solution but outside the boundary layer to free stream the velocity increses from 1.00 to 1.008 and again approaches to 1.00 ,which is not perfect from boundary layer solution point of view. which is expected to exactly 1.00 m/s. i.e in any circumstance U should not more than 1.00 m/s.
Thanks in advance for in suggestion to correct it.
rameshbhoraniya is offline   Reply With Quote
Old   August 28, 2013, 06:27
flotus1's Avatar
Alex
flotus1 has a spectacular aura aboutflotus1 has a spectacular aura about
Why dont you post a picture? That would really help in understanding the problem you are facing.
rameshbhoraniya likes this.
flotus1 is offline   Reply With Quote
Old   September 7, 2013, 00:53
Default Boundary Layer Flow
Dear please see the attached file , for velocity profile at trailing end.
Old   September 7, 2013, 02:26
duri
duri is on a distinguished road
This is perfect. Local mass defect in boundary layer will produce this local acceleration and it will appear in all NS solvers.
duri is offline   Reply With Quote
Wind turbine simulation Saturn CFX 58 July 3, 2020 01:13
domain imbalance for enrgy equation happy CFX 14 September 6, 2012 01:54
[snappyHexMesh] Boundary layer in a pipe Clementhuon OpenFOAM Meshing & Mesh Conversion 6 March 12, 2012 12:41
How to use a solution as an inlet boundary condition in another problem in fluent geryes FLUENT 0 February 25, 2010 16:32
New topic on same subject - Flow around race car Tudor Miron CFX 15 April 2, 2004 06:18
