SOS!! Periodic BC
Like Tree2Likes
  • 1 Post By sbaffini
  • 1 Post By wux
Old   October 30, 2013, 23:25
Default SOS!! Periodic BC
Prashant Thaker
prashantthaker208 is on a distinguished road
hi, I am a new user to fluent, trying to model pollutant dispersion in air. my geometry consists of two lines of buildings with a street(releasing pollutant) in between. the inlet of ambient air is 100m behind the buildings. I need to specify such a boundary condition which keeps the same wind velocity profile at the inlet and at the plane containing building rooftop.
I tried transalational periodic bc but got an error:
'no. of faces not the same'
so 2 questions:
1. is translational periodic bc fit for my requirement?
2.how to get rid of the above mentioned error.
I am using FLUENT meshing. Don't have access to other software.
plz help!!
Prashant
prashantthaker208 is offline   Reply With Quote
Old   October 31, 2013, 01:52
sbaffini's Avatar
Paolo Lampitella
sbaffini will become famous soon enoughsbaffini will become famous soon enough
Send a message via Skype™ to sbaffini
First of all, when using periodicity among any two faces, they have to be exactly the same (e.g., a square and an identical traslated/rotated square, a circle and an identical traslated/rotated circle).
Second, i don't know if you can actually have both rotation and traslation among the two faces. I guess not.
Third, in the basic periodicity approach as implemented in Fluent, the grids on the two faces also have to be exactly the same. To do this in Gambit (e.g., when the grid is not structured) you have to link the two faces before meshing them. In this case, you don't need to bother about setting specific boundary conditions in Gambit; just set the two faces as walls and then apply periodicity among them in Fluent trough (TUI):
grid->mo->mp
I don't know how the grid part is done in fluent meshing (Fluent 14.5?).
Another possibility in Fluent is to use interfaces among the two faces. In this case you don't need the same grid. Refer to the manual for this case.
prashantthaker208 likes this.
sbaffini is offline   Reply With Quote
Old   October 31, 2013, 07:01
wux
wux is on a distinguished road
i am using 'Match Control' when meshing.
... and the '/mesh/modify-zones/make-periodic' command in Fluent.
wux is offline   Reply With Quote
Old   November 1, 2013, 03:16
sbaffini's Avatar
Paolo Lampitella
Dear Prashant,
i'm sorry but i forgot to mention that you may have problems in doing scalar transport in Fluent with periodicity. It is allowed for the temperature, but then some specific scaling is used in Fluent among the periodic faces to avoid having a constant rise in temperature or a uniform temperature at regime. You should check the manual on this.
[GAMBIT] periodic faces not matching Aadhavan ANSYS Meshing & Geometry 6 August 31, 2013 11:25
[ICEM] Shifted Periodic topology venkat_aero2007 ANSYS Meshing & Geometry 17 August 27, 2013 01:41
[ICEM] Periodic condition between ICEM and FLUENT Touré ANSYS Meshing & Geometry 0 August 5, 2012 17:00
HELP! Periodic Problem foxer FLUENT 1 June 27, 2012 08:00
[ICEM] how to define periodic in icem ? mingersai ANSYS Meshing & Geometry 1 February 3, 2012 17:46
