Deforming Mesh in Fluent but Cells keep stretching! |
January 7, 2014, 04:05 |
david
Rep Power: 13 |
I'm trying to create a dynamic mesh in Fluent. It's basically a square that that increases with height. I have been getting problems with the deforming of the mesh. Basically, the mesh keeps stretching rather than create new cells everytime it increases in height. It is a tetrahedral mesh so i cant use the layering method. I disabled the smoothness option and kept it to the remeshing option in the gui. Can anybody help? i have attached a picture of my problem. Hope to get some reply soon. |
January 7, 2014, 11:17 |
Rep Power: 13 |
What are the deforming conditions you imposed in the Dynamic mesh zone box? Are the side walls set to deforming and the moving wall Rigid Body ? |
January 7, 2014, 15:37 |
david
Rep Power: 13 |
the box (meshed as one entity) deforms as a rigid body and it's base is modelled as stationary.
January 8, 2014, 02:45 |
Rep Power: 13 |
Ok,
Maybe try to impose the following conditions on the surfaces : - moving wall : rigid body - opposite wall (to the moving one) : stationary - side walls : deforming (You don't need to impose any deforming condition on the box volume.) |
December 20, 2016, 12:40 |
Rep Power: 10 |
Hi there
Could you please explain how you resolved this problem. I've encountered something very similar in a 2D rectangular domain with a moving circle in middle (when the particle moves, mesh cells near the wall are getting stretched). Thanks |
June 21, 2021, 04:12 |
stretch wall
fateme
Rep Power: 5 |
i have same problem my wall stretching when my door moving. door is between two room i use dunamic mesh smoothing and remeshing
Problem with divergence | TDK | FLUENT | 13 | December 14, 2018 06:00 |
How to open Icem mesh in Ansys Fluent? | emmkell | FLUENT | 27 | February 6, 2018 03:34 |
Moving mesh | Niklas Wikstrom (Wikstrom) | OpenFOAM Running, Solving & CFD | 122 | June 15, 2014 06:20 |
fluent add additional zones for the mesh file | SSL | FLUENT | 2 | January 26, 2008 11:55 |
How to control Minximum mesh space? | hung | FLUENT | 7 | April 18, 2005 09:38 |
