January 22, 2014, 07:36 |
isothermal medium
Rep Power: 12 |
I am studying the heat transfer rate within an isothermal medium which is not moving(still) and it s at temp T1. The medium is confined within two large black isothermal walls of temp T2.
If we have to specify a wall as isothermAL, we can just give the value of the temperature in boundary conditions>>edit>>thermal >>thermal conditions>>temperature.... Am i right?? And if we want to specify a medium (fluid /solid) as isothermal, how to give a specified temperature for that? Because in boundary conditions panel, for solid or fluid, we can only edit the name and nothing else.. pls tell me how to specify a still medium as isothermal... ?? Do we have to specify it in reference values section ?? or do we have to give it under cell zone conditions>>edit>>Fixed values>>Temperature ??? I tried it with fixed value once an as i am wrking in radiation heat transfer problems, i dont think I am right.. Someone pls suggest me the right way pls.. |
Turbulent flow in porous medium | Chander | CFX | 4 | January 17, 2017 09:50 |
isothermal medium | myaccount | Main CFD Forum | 0 | January 22, 2014 05:42 |
Lack of local thermal equilibrium in porous medium | Chander | CFX | 4 | March 4, 2012 04:07 |
How to use non-equilibrium thermal model for porous medium in Ansys CFX 13.0? | Chander | CFX | 3 | November 28, 2011 14:26 |
porous medium and reactions | Valeria | FLUENT | 1 | July 10, 2009 03:58 |
