2d conjugate heat transfer
Old   February 10, 2014, 02:40
Default 2d conjugate heat transfer
ruben303 is on a distinguished road
Hi, I'm trying to carry out a conjugate heat transfer in fluent. I'm having issues in creating a shadow wall between the solid and fluid. Any ideas how to create a solid and fluid zone in the design modeller so as to create the shadow wall ? it's a 2d problem
ruben303 is offline   Reply With Quote
Old   February 10, 2014, 07:47
Bionico's Avatar
Flavio
Bionico is on a distinguished road
Hi ruben,
if you need coupled walls (with shadow wall auto-creation and heat flux) in the pre-processing you have to put all the bodies in the same part in order to generate a conformal mesh. Otherwise, if you generate a non-conformal mesh, you have to define interfaces zones (but the first choice is usually the best).
Best Regards
Bionico
Bionico is offline   Reply With Quote
Old   February 10, 2014, 08:29
Originally Posted by Bionico View Post
Hi ruben,
Best Regards
Hi ,
Thx for your reply. I'm still strugling with that concept especially in 2d. Could you plz post an example or tutorial ?
Regards
Ruben
Question about heat transfer coefficient setting for CFX Anna Tian CFX 1 June 16, 2013 06:28
Error finding variable "THERMX" sunilpatil CFX 8 April 26, 2013 07:00
Heat Flux at wall in a conjugate heat transfer problem Chander CFX 2 July 9, 2011 22:22
Convective / Conductive Heat Transfer in Hypersonic flows enigma Main CFD Forum 2 November 1, 2009 22:53
Convective Heat Transfer - Heat Exchanger Mark CFX 6 November 15, 2004 15:55
