Ideal gas errors using density-based solver
Old   April 13, 2014, 16:48
Default Ideal gas errors using density-based solver
crustaccione is on a distinguished road
I didn't get an answer for my previous thread, but I do have one question regarding ideal gas equations. My tank that I am simulating is being pressurized to 1000 psi for initial conditions, and then released into the atmosphere through a hose.
I am using the density-based solver. Problem is, the solution does not converge when I set the properties to ideal gas. It works when I set it to constant density of 1.225 kg/m3, but that is obviously not physically correct. There is also a large temperature fluctuation and Fluent gives warnings.
Is there any way to correct this?
crustaccione is offline   Reply With Quote
Old   April 13, 2014, 17:04
WJXu is on a distinguished road
Similar problem encountered. Mine problem is burner with pressure 5psig and expand to sonic through a converging nozzle. I also did use constant-density for my calculation, which is not correct. I think ideal gas must be used, then the mass flow rate cannot balance. Help us。。。。
WJXu is offline   Reply With Quote
Pressure based and Density based Solver Xobile Main CFD Forum 39 August 19, 2020 06:04
How to write k and epsilon before the abnormal end xiuying OpenFOAM Running, Solving & CFD 8 August 27, 2013 15:33
how to extend solver compressibleInterFoam to consider ideal gas jianfeng OpenFOAM Programming & Development 6 March 1, 2013 13:52
Pressure based and Density based Solver taekyu8 FLUENT 0 January 28, 2013 11:05
Pressure gradient in UDF for density based solver matzb FLUENT 0 February 22, 2010 06:34
