Need help for simulating constant pressure combustion in fluent
Old   March 18, 2014, 14:43
Default Need help for simulating constant pressure combustion in fluent
shanglong
Shanglong is on a distinguished road
Hi all,
I am simulating a 1-d constant pressure combustion problem in chemkin.It is a premixed laminar flame simulation.Mass flow inlet and pressure outlet.For this problem, we don't need to worry about momentum equation because pressure has already known. We only need to solve continuity equation, energy equation, species equation and ideal gas equation.
Now I want to do the same thing in Fluent.However, it seems like difficult to set up a constant pressure condition in fluent.Does anyone has any idea about this?or can I disable momentum equation individually?I try to use DEFINE_SOURCE in UDF to eliminate momentum equation,but i don't know if is a correct way to do this.
Is there anyone knows how to set up a constant pressure condition for a 1-d pipe?or how to disable momentum equation?
Thanks
Shanglong is offline   Reply With Quote
chemkin, combustion, momentum source, pressure and velocity, udf
looking for a smart interface matlab fluent chary FLUENT 24 June 18, 2021 09:07
Setting Pressure in FLUENT sampathevs FLUENT 2 August 10, 2013 01:19
Pulsatile pressure inlet with pressure outlet a.lynchy FLUENT 3 March 23, 2012 13:45
Pressure BC for combustion chamber Giuki FLUENT 1 July 19, 2011 11:35
pressure inlet bc in fluent nikhil FLUENT 0 June 28, 2010 16:30
