Error with boolean subtract in Design Modeler |
March 25, 2014, 05:30 |
mattk
Rep Power: 12 |
I have a brought a stent (complex geometry) into the design modeler, and around it have put a cylindrical enclosure, both bodies are frozen. When I try to perform a boolean subtract (target body is the cylindrical enclosure and tool body is the stent) I get the following error: Error: Boolean operation failed Context: Geometry Engine, while generating Feature Boolean4 does anyone have any suggestions as to how I might get around this? maybe there is a way of simplifying the stents geometry within the design modeler? any help would be greatly appreciated!! thanks Matt |
March 25, 2014, 06:48 |
anbu
Rep Power: 12 |
if you have used enclosure tool in design modeler, there is no need of boolean operation. just suppress the engine body.you will be left only with fluid domain.
April 2, 2014, 16:07 |
shafqat
Rep Power: 12 |
i have import the Vertical axis wind turbne from pro e to design modler.After making enclosure when i go for mesh then it does not read the turbine...whats the problem?Am i missing some steps in design modler before meshing?
April 3, 2014, 00:24 |
anbu
Rep Power: 12 |
are you making use of enclosure tool from design modeler or your creating outer box in design modeler. if so try to freeze your body and then suppress the solid domain.
April 3, 2014, 05:12 |
mattk
Rep Power: 12 |
thanks for the suggestions, have it sorted now
April 5, 2014, 06:54 |
shafqat
Rep Power: 12 |
thank you for your help!!
March 12, 2018, 10:23 |
Naveen Kumar Gulla
Rep Power: 8 |
how to freeze body and then suppress the solid domain in ansys
boolean subtract, fluent |
[Other] Connecting 3D bodies in Ansys Design Modeler | chipper | ANSYS Meshing & Geometry | 4 | January 25, 2018 09:45 |
[DesignModeler] How to write the script in the ansys design modeler? | deddy1973 | ANSYS Meshing & Geometry | 3 | October 4, 2013 05:08 |
Info message -> Fluent does not start | Jenson | FLUENT | 0 | December 22, 2011 17:21 |
Design Modeler not working | tan v | ANSYS | 0 | July 7, 2011 02:43 |
Info: Short Course On Thermal Design of Electronic Equipment | Arnold Free | Main CFD Forum | 0 | August 10, 1999 10:18 |
