How to display Reynolds stresses
Like Tree1Likes
  • 1 Post By Padmabhushana r. Desam
Old   March 30, 2003, 14:30
Default How to display Reynolds stresses
ravi
Hi, I am using a 2d model utilizing the k-epsilon RNG turbulence model, to simulate an open channel flow. How can i display the reynolds stresses at the node points. Under the display option there is none that i know of. Thanks for the help
regards Ravi
Old   March 31, 2003, 03:35
Default Re: How to display Reynolds stresses
Hi, Fluent does not have the Reynolds stresses option in the post-processing for k-epsilon family since it does not solve Reynolds stresses explicitly. The Reynolds stresses are modeled with Boussinesq approximation. If your problem demands accurate Reynolds stresses distribution, use the Reynolds stress turbulence model instead. If you are looking for a crude approximation, write a custom defined function using Boussinesq approximation, which relates the local mean velocity graidents to the Reynolds stresses through eddy viscosity.
Hope it helps
Good luck Bhushan
maphd likes this.
Old   April 14, 2014, 12:53
maphd is on a distinguished road
Originally Posted by Padmabhushana r. Desam
;105140
Hope it helps
Good luck Bhushan
Hi, Padmabhushana
I need help about your above post? I am new to fluent, so if you could give me more detailed explanation, I really appreciate it. Could you explain to me how I can write custom defined function to calculate Reynolds stresses? I am using k-e model in turbulent flow.
maphd is offline   Reply With Quote
Scaling the Reynolds stresses via UDF Markus FLUENT 1 November 11, 2022 12:44
what are reynolds stresses UnderGroundMan FLUENT 4 November 10, 2008 03:07
Reynolds stresses without velocity correlations? Phil Main CFD Forum 1 October 2, 2006 04:29
Reynolds stresses and second law JF Main CFD Forum 6 June 2, 2005 22:57
Display Reynold Stresses in K-E Andrew FLUENT 4 April 16, 2004 18:12
