Simulation of Vertical axis wind turbine
Old   April 12, 2014, 10:08
Default Simulation of Vertical axis wind turbine
sa
sasasa is on a distinguished road
I have designed and meshed a VAWT in Gambit,with different mesh zones as shown in the attached figure.The ring has to rotate as moving mesh at 3 r/s.
What are the settings required for it?Dynamic mesh-negative volume error appears when calculating. What is the udf required?
sasasa is offline   Reply With Quote
Old   April 12, 2014, 16:18
Far
Sijal
Far has a spectacular aura aboutFar has a spectacular aura about
Send a message via Skype™ to Far
You can do it with the help of sliding mesh and frozen rotor model.
Far is offline   Reply With Quote
Old   April 13, 2014, 02:42
Default VAWT simulation
sa
I need to make the ring rotate(moving mesh). Interfaces are defined.What is the setting/udf ?
Old   April 13, 2014, 06:28
Far
Sijal
you should go for sliding mesh. You will see the ring is moving. Results with dynamic mesh and sliding mesh will be same.
Old   April 13, 2014, 11:01
sa
I tried mrf model.It produces divergence with many settings..The inner ring has to rotate.Could you list the settings.The ring is defined as a separate zone
Old   April 14, 2014, 04:55
Behrooz Jamshidi
CFD-fellow is on a distinguished road
Hi
for simulating sliding mesh (which is a sub branch of dynamic mesh, but the difference is that the cells move rigidly without any geometrical change), you should provide two interfaces locating on each other, one belong to rotating zone and the other to stationary one.Then the following procedure lead you to correct answer:
1-change the solver to unsteady
2-change the ring zone from stationary to sliding mesh
3-couple the two interfaces from define>grid interface
3-choose a time step so that the ring rotates 1 degree
4-then about 30 iteration per time step is enough in your case i think
Best regards
CFD-fellow is offline   Reply With Quote
Old   April 14, 2014, 07:18
sa
The outer circle is 1 interface.The inner circle is 1 interface.The ring between the 2 contains a separate mesh which has rotate at 3 r/s.The remaining mesh is separate and stationary.There are only 2 concentric interfaces and 2 cell zones.Where is sliding mesh option under dynamic mesh(fluent 12)picture is attached
Old   April 17, 2014, 08:03
Ali
mct90 is on a distinguished road
How did you define outer circle's diameter? And the outer domain? Is there any reference for them?
mct90 is offline   Reply With Quote
moving mesh, udf, vawt
High torque coefficient Cm for Vertical Axis Wind Turbine (VAWT) tony00 FLUENT 11 July 23, 2018 06:13
[ICEM] Boundary conditions in copy-rotate 3-bladed vertical axis wind turbine pollenhavy ANSYS Meshing & Geometry 2 February 17, 2017 17:01
Wind turbine simulation in Ansys CFX aalbanesi CFX 50 January 18, 2017 12:02
Vertical Axis Turbine Simulation dalecooper FLUENT 3 July 24, 2013 08:53
Vertical axis wind turbine CFD Analysis Akhilesh FLUENT 4 April 13, 2012 16:44
