k-omega SST near-wall mesh
Like Tree1Likes
  • 1 Post By Kina
Old   April 16, 2014, 07:56
Default k-omega SST near-wall mesh
spellkun is on a distinguished road
Hello everyone,
I'm doing calculations on an air inlet (a pipe, basically), the objective being the evaluation of the total pressure losses at a certain distance. I use the pressure-based solver, steady, k-omega SST for turbulence.
I have doubts concerning the mesh I should generate: I have noticed that Fluent doesn't offer the choice between wall-law/low-Re concerning the near-wall modeling, and I assumed that it picked the appropriate model, according to the Y+ of the near-wall layer.
This extract from the Fluent User's Guide seems to confirm my hypothesis:
"The wall boundary conditions for the k equation in the k-omega models are treated in the same way as the equation is treated when enhanced wall treatments are used with the k-epsilon models. This means that all boundary conditions for wall-function meshes will correspond to the wall function approach, while for the fine meshes, the appropriate low-Reynolds number boundary conditions will be applied."
In order to generate lighter meshes, I chose the wall-law approach, and I made sure that the Y+ was always between 30 and 200, as close as possible to 30.
My professor, however, just told me that the k-omega SST model is supposed to be used only with low-Re meshes, and that If I wanted to keep the cell count low, I had to switch to the k-epsilon or standard k-omega models.
I'd like to stick with the k-omega SST since it should combine the strengths of the k-epsilon and std k-omega models... could someone clarify the point concerning the meshes? Am I obliged to generate low Re grids if I want to use the K-omega SST model?
Thanks!
spellkun is offline   Reply With Quote
Old   April 17, 2014, 18:19
Alex
Kina is on a distinguished road
Not necessarily. The thing is that k-omega is good for near-wall modeling with a y+ of around 1 while k-epsilon is good for fully turbulent free stream flow. Thus, k-omega lacks accuracy when applied to fully turbulent farfield flow whereas k-epsilon models the near-wall region with wall functions.
The k-w SST model combines the advantages of both approaches as it includes a blending function (F1) that switches from k-w in the nearfield to k-e in the freestream flow. This is obviously also a function of the local y+ value. If you are using a y+ of 30 and the k-w SST model, you won't take advantage of the accurate boundary layer resolution of the k-w model as you would effectively only make use of the k-e model.
What I want to say is: If you are using the k-w SST model with a y+ of 30, you could also just use the realizable k-e with enhanced wall treatment as it wouldn't really make any difference.
pavlossemelides likes this.
Kina is offline   Reply With Quote
Old   April 18, 2014, 03:54
I understand, thanks a lot!
Old   November 7, 2014, 10:15
Unhappy OMGA on the wall in SST
Ali.E
behest is on a distinguished road
Dear all,
I am working with Fluent and I have simulated a flat plate and the mesh is enough refine (Y+<=1). The turbulence model that I use is k-w SST and I uncheck Low-Reynolds-Number in the turbulence panel. My goal is to obtain the equation that Fluent uses for OMEGA value on the wall surface. Therefore, I compared the omega value on the plate surface obtained by Fluent and mine; but they are not the same and they are exactly different. I used this equation:
OMG=sqrt(OMG_vis^2+OMG_log^2)
OMG_vis=6*ro*(U_tau^2)/(0.075*Mu*Yplus^2)
OMG_log=ro*(U_tau^2)/(0.3*k*Mu*Yplus)
ro=dinsity
U_tau=friction velosity
Mu=viscosity
k=0.41
It would be appriciated if you help me about the equation. How can I get the same OMGA value with Fluent?
behest is offline   Reply With Quote
Wall treatment mesh refinement in k-omega SST model Jorg FLUENT 0 February 27, 2013 11:32
[ICEM] Export ICEM mesh to Gambit / Fluent romekr ANSYS Meshing & Geometry 1 November 26, 2011 12:11
Convergence moving mesh lr103476 OpenFOAM Running, Solving & CFD 30 November 19, 2007 14:09
