May 20, 2014, 03:40 |
Continue a finished calculation
Rep Power: 12 |
Hey guys,
i have a question according Fluent. I already finished some transient simulations with 5000 time-steps. Now i want to use their results but change some settings. Lets say i want to start at time step 2500 of the old simulations, change settings an calculate from this point. When i try to do this my flow time jumps back to 0....is there anyway to solve this problem? Thanks a lot! |
May 20, 2014, 04:09 |
Flavio
Rep Power: 15 |
Hi FluentStarter,
unfortunately there isn't possibility to restart the simulation from a previous time-step: if you want to fix a reference time you have to save your case at this step (so, for example, you have to save your data after 2500 time-step). If you have a case saved you can start from its results! Regards
Bionico |
May 20, 2014, 04:25 |
Rep Power: 12 |
Hi Bionico,
thanks for your rapid reply. Maybe I explain my case: I simulate a cylinder filled with gas. Then this gas is compressed by a piston. At step 2500 the piston reaches the BDC. I already simulate this case till the step 2500,changed my dynamic mesh options so that the piston doesnt move any more and simulated 2500 more steps. This worked well! Now i want to use the first 2500 steps, simulate 100steps more to drive the piston a bit back and then stop his motion for about 2400 steps. I have have autosaved .dat and .cas files everey 50 timesteps. I tried it with import fluentcase and it opens the case at step 2500. But when i want to start it again, i have to problems: 1. I have to initialize the solution: How do i do this? I cant use the same values that i used before step 0. 2. When I try it like this my flow time is resetted.... Thankyou =) |
May 20, 2014, 05:50 |
Flavio
Rep Power: 15 |
It's very strange: are you sure that the .DAT file is loaded correctly?
Regards
Bionico |
May 20, 2014, 06:02 |
Rep Power: 12 |
I donīt load the .dat-file. I load the .cas.gz-file via import case-file
May 20, 2014, 06:04 |
Flavio
Rep Power: 15 |
You have to import even .DAT file in order to start the simulation from the point it finished!
Regards
Bionico |
May 20, 2014, 06:08 |
Rep Power: 12 |
Okay...its really strange. I work with Ansys Workbench and when i click on import case-file directly in the project it does not work.
Now i started Fluent without loading any data and clicked in import data there....time flow is fine now...i`ll calculate some steps and see what happens to pressure and temperature! Thanks anyway Bionico |
May 20, 2014, 07:57 |
Flavio
Rep Power: 15 |
Usually I work on Fluent separately from Workbench: I suggest reading ANSYS Manuals, anyway probably you have to connect Results in the workflow.
Best Regards
Bionico |
How to continue calculation after the computer is abruptly shut off? | superqtp | CFX | 5 | September 25, 2012 08:53 |
continue calculation with a reduced domain | kharnabnew | FLUENT | 0 | September 27, 2009 14:29 |
[blockMesh] BlockMeshmergePatchPairs | hjasak | OpenFOAM Meshing & Mesh Conversion | 11 | August 15, 2008 07:36 |
Warning 097- | AB | Siemens | 6 | November 15, 2004 04:41 |
EULER-Forward-Method | freak | Main CFD Forum | 4 | June 12, 2001 09:19 |
