Wall Boundary Conditions Problem for Convective Heat Transfer
Like Tree1Likes
  • 1 Post By nvarma
Old   September 7, 2016, 07:08
Default Wall Boundary Conditions Problem for Convective Heat Transfer
Onur Özcan
oozcan is on a distinguished road
Hi all,
I am working on temperature distribution of solid having 1473K melt glass in its center.I have defined wall boundary conditions in some faces of solid( trivial faces). That's why you could see 323K temperature in attached first photo. (Blue colour is seen in PP). thing I want to specify was only initial temperature for the boundary condition. But temperature value in those faces was constant according to defined time.
Similarly,second attached photo is to be seen 1473K because of wall boundary condition.
Both problems influence convective heat transfer in trivial ways.
Remaining photos are enough for me. kind of correct (depending on mesh)
oozcan is offline   Reply With Quote
Old   September 7, 2016, 17:35
nm
nvarma is on a distinguished road
Initial conditions have to be set by initialization/patch.
BCs are held constant unless you have a udf to change it in a time dependent manner.
nvarma is offline   Reply With Quote
Old   September 8, 2016, 01:50
Onur Özcan
I have defined temperature in regarding zone. Similarly, it should be given in another zone,too. How can I add ''register to patch'' in patch view.
I see what you said. But some faces are trivial. I had to do/draw them because of being real one. Then the best bc's given them are wall. and they all fixed in all calculation.
as far as I know , answer is how I can add regarding zones registers to patch in patch view.
Old   September 8, 2016, 08:46
nm
Are you talking about cell zones? I thought you wanted to set initial temperature on a wall.
Registers are created using cell adaptation tools in the "adapt" menu.
Old   September 8, 2016, 08:52
Onur Özcan
How can I use '' cell adaptation tools'' in adapt.
Now, I am checking it and ?
Old   September 8, 2016, 08:55
Onur Özcan
Yes I am trying to give initial temperature for a wall.
Old   September 8, 2016, 15:10
nm
yeah... then go to adaptation>boundary> and mark.
oozcan likes this.
Old   September 8, 2016, 15:45
Onur Özcan
if another patched one is cell zone, is it necessary to do ''patch to register''? or it is already available to found in patch consol in initilazation That's why it is nonsense?
Kind Regards,
Thanks ,
Domain Imbalance HMR CFX 5 October 10, 2016 05:57
Error - Solar absorber - Solar Thermal Radiation MichaelK CFX 12 September 1, 2016 05:15
Radiation interface hinca CFX 15 January 26, 2014 17:11
Water subcooled boiling Attesz CFX 7 January 5, 2013 03:32
Heat Flux at wall in a conjugate heat transfer problem Chander CFX 2 July 9, 2011 22:22
