June 17, 2014, 00:59 |
Les
khar nab
Rep Power: 16 |
Dear all,
I would like to understand what kind of results does fluent provide when applying Large Eddy Simulation with the dynamics SGS model. Are the resulting fields in Fluent just the resolved ones? do they include the modeled part? Thanks |
June 17, 2014, 14:18 |
Dear khar,
the resulting fields provided by Fluent with the LES model are, as for all the codes i know, the resolved fields. That is, the implicitly filtered fields due to the top-hat filter implied by the Finite volume formulation + the implicit filter due to the grid resolution + the implicit filter due to the numerics + the still somehow implicit filter due to the SGS model itself (as it also damps some of the smallest resolved scales, or at least it is supposed to do so). Some of the filtered scales, more specifically those due to the finite volume top-hat filter, could be recovered on the given grid but this is not done in Fluent. All the other scales are not actually recoverable and any attempt to do so must necessarily imply some modeling (e.g., the used SGS model itself or any other suitable model). This does not depend from the SGS model itself but from the adopted approach and, in the end, by the convenience to do differently. |
LES Filtering: how are the small and large scales equations solved? | atmcfd | Main CFD Forum | 38 | March 14, 2016 14:52 |
Beginning to work in LES - Suggestions needed | atmcfd | Main CFD Forum | 5 | July 20, 2012 22:16 |
Turbulence dampening due to magnetic field in LES and RAS | eelcovv | OpenFOAM | 0 | June 8, 2010 11:35 |
LES and combustion model | Margherita Cadorin | CFX | 0 | October 29, 2008 05:24 |
Some Questions about LES. | Bin Li | Main CFD Forum | 2 | February 20, 2004 09:58 |
