How can I change chemical formula with text command?
Old   June 22, 2014, 18:22
Question How can I change chemical formula with text command?
Juun
Juun is on a distinguished road
Hi everyone, I got a little problem with text command.
in my case, ammonia is added into material at the beginning, then I use below command to copy it and create a new material nh3-1 (just a random name)
/define/materials/change-create ammonia-vapor nh3-1 no no no no no no no no no no no no no
But I want to change the chemical formula to, nh3-a, for example.I done a lot search, but haven’t found anything so far. What command can I use to change this?
Thank you very much for any help
Juun is offline   Reply With Quote
Old   June 22, 2014, 20:55
Christopher Hershey
Hershey is on a distinguished road
I seem to recall having trouble with this as well. Instead I made a user defined material database and read that into fluent instead.
Hershey is offline   Reply With Quote
Old   June 23, 2014, 20:12
Juun
Hi Hershey, Thank you very much. problem sloved, I tried it on windows platform.
will it also work on hpc cluster? if i upload the database together with mesh...
Old   June 23, 2014, 22:08
Christopher Hershey
Yes. As long as the database is in the same folder as your journal file (or working directory) it will work.
Working directory via command line Luiz CFX 4 March 6, 2011 20:02
Installation OF1.5-dev ttdtud OpenFOAM Installation 46 May 5, 2009 02:32
TEXT COMMAND Alex Munoz FLUENT 0 April 10, 2003 22:32
Text command sam FLUENT 2 April 2, 2003 05:24
Text command of monitor-command? Mika FLUENT 0 March 27, 2001 13:46
