October 21, 2014, 16:20 |
Two questions about heat exchanger
ayden
Rep Power: 11 |
Hi every one
I simulate turbulent cross flow finned tube heat exchanger shown below by using fluent, and study the same case experimentally. I've tow problems
I'm looking for answer or any site can answered me please thank you
October 22, 2014, 07:58 |
Rick
Rep Power: 26 |
your question is not clear (at least for me)...where you want to calculate Re number?What's your 2nd problem? |
October 22, 2014, 08:18 |
ayden
Rep Power: 11 |
-depending on the model's image which way is the right to measure Reynold number ( based on duct hydraulic diameter or pipe hydraulic diameter).
-the second problem the hydraulic diameter of pipe is simple to calculate, but how to calculate the hydraulic diameter taking in consideration the fins. |
October 22, 2014, 09:12 |
Flavio
Rep Power: 15 |
Hello Ice man,
I suggest using pipe diameter for internal flow Re (water), and fin diameter in order to calculate external flow Re (air) in your boundary conditions. Best regards
Bionico |
October 22, 2014, 09:19 |
ayden
Rep Power: 11 |
October 22, 2014, 10:53 |
Flavio
Rep Power: 15 |
Actually I based the reply on my experience: usually in heat transfer the Caracteristic Dimension of the system is the fin dimension (lenght for longitudinal fin, diameter for radial fin).
I'm sure there are lot of articles about these kind of systems. Regards
Bionico |
October 22, 2014, 11:27 |
ayden
Rep Power: 11 |
Thank you so much Bionico
final question please:I need justification to write that in my thesis, do you have any idea about the reason of using fin diameter. Is this as a type of safety factor? |
October 23, 2014, 08:15 |
Flavio
Rep Power: 15 |
Well, characteristic parameters aren't always objective: it depends on which dimension (or temperature, pressure...) you think is representative of your system.
About heat exchanger with extended surfaces (fins) I'm sure that Heat transfer Theory suggests using the lenght of the fin as characteristic lenght because boundary layer and turbulent parameters depend on this dimension. Another example: if you simulate an aerodynamic profile the characteristic lenght is the chord of the wing, etc... In your case I would choose diameter for water (in internal flow hydraulic diameter is usually used in correlations, or the radius too) and fin-diameter for air. I have only a doubt: does the air flow in a duct or are you simulating an external system (open space)? In the first case you might also choose the hydraulic diameter of the duct, taking into account that it isn't circular (anyway I prefer fin lenght because the main physical phenomenon in your system is the heat transfer). Sorry for my bad english Regards
Bionico |
October 23, 2014, 13:16 |
#9 |
ayden
Rep Power: 11 |
Thank you so much man, you lost more and more of your time because me.
I was found some article support your opinion, and an other calculate hydraulic diameter as below Dh=4a/b where: a:Ratio of free flow area (up, bottom, and sides of heat exchanger) to the stagnation area(where air collide the heat exchanger). b:Total surface area for one side of heat exchanger to the total volume of heat exchanger. Do you have any idea? |
October 24, 2014, 05:52 |
#10 |
Flavio
Rep Power: 15 |
Ok, it seems that there are some more specific formulas about your problem (what I said in previous post was referred to a more general theory about fins and heat transfer with extended surfaces): well, you can choose this one, it sounds good!
Best Regards
Bionico |
October 24, 2014, 07:26 |
#11 |
ayden
Rep Power: 11 |
OK man,
thank you for your effort |
Double pipe heat exchanger | mohcin | FLUENT | 21 | June 18, 2016 14:19 |
transient source term | strakakl | OpenFOAM | 38 | November 19, 2013 01:18 |
Modelling serpentine heat exchanger | andbe | ANSYS | 0 | September 30, 2013 09:08 |
Heat Exchanger Efficiency | NTM | FLUENT | 0 | September 19, 2008 02:19 |
Convective Heat Transfer - Heat Exchanger | Mark | CFX | 6 | November 15, 2004 15:55 |
