which boundry condition is used for an opening
Like Tree5Likes
  • 1 Post By marauder
  • 2 Post By pakk
  • 2 Post By stuart23
Old   November 6, 2014, 03:56
Question pls quick help :which boundry condition is used for an opening
jonior is on a distinguished road
in boundary condition i want to ask about if i have an opening (not pressure in or out) just opening i want from the simulation to predict if the flow will goes out from it or it will be like a vacuum ??? which boundary condition should i use in fluent (note: in CFX boundary condition has a type called opening i didn't found the same in fluent)
jonior is offline   Reply With Quote
Old   November 6, 2014, 08:05
pls did any one know the answer my simulation is stopped bcz i couldn't adjust it
Old   November 6, 2014, 22:53
Anonymous
marauder is on a distinguished road
I think 'Outflow' boundary condition should help. But a better explanation of problem would be good to decide.
marauder is offline   Reply With Quote
Old   November 8, 2014, 05:30
no, i cannot use outflow bcz i am modeling a compressible flow t t the socend outle
in my problem i have 4 pressure inlets and 2 outlets for air one of them i know that the pressure will goes out from it but the second outlet i dont know if the pressure will goes out or will be reversed to goes out from the first out let
Old   November 10, 2014, 03:51
Anonymous
Originally Posted by jonior View Post
In my problem i have 4 pressure inlets and 2 outlets for air one of them i know that the pressure will goes out from it but the second outlet i dont know if the pressure will goes out or will be reversed to goes out from the first out let
Then outlets will be pressure oulets with the pressure at outlet to be specified.
jonior likes this.
Old   November 10, 2014, 05:17
Jamal Foroozesh
jamalf64 is on a distinguished road
Hi dear friend
I think you can use symmetry boundary condition. Its Ok.
jamalf64 is offline   Reply With Quote
Old   November 10, 2014, 10:08
pakk will become famous soon enough
Originally Posted by jamalf64 View Post
Hi dear friend
Don't do this. A symmetry boundary condition will block flow, so it is not ok.
If you don't know if it is an inlet or an outlet, I would start by assuming it is an outlet. Select the "pressure outlet" boundary condition, and apply the pressure on the outside of your inlet/outlet.
Then do your simulation until it converges. You might see messages like "20 faces in surface 40 have reversed flow" (I don't remember the exact phrasing), this means your "outlet" is really an inlet (or at least partially). Once your simulation has converged, look at the solution. If your "outlet" has fluid coming into the system, your guess was wrong. In that case, change it into an inlet.
jamalf64 and jonior like this.
pakk is offline   Reply With Quote
Old   November 10, 2014, 10:16
Stuart Buckingham
stuart23 will become famous soon enoughstuart23 will become famous soon enough
If it is a compressible simulation, you should be using pressure far-field
Stu
stuart23 is offline   Reply With Quote
Old   November 12, 2014, 12:29
Thumbs up
thanks for all. i am trying in inlet and outlet
but i don't know about far-field could you explain more.
Old   November 8, 2017, 09:55
Default inlet and outlet boundry
maryam
maryam74121 is on a distinguished road
hi every one
im simulating a kind of micro chamber which has 4 vents for air it means that this boundry can be inlet and outlet simultaneously just for air and it shouldnt pass phase 2 (water) across itself.which boundry i can use?
my simulation is vof and transient
im glad to hear from you
tnx
maryam74121 is offline   Reply With Quote
Fan boundary condition John peter FLUENT 2 June 4, 2014 06:33
Fan Boundry Condition problem, Ozora FLUENT 0 December 9, 2013 07:26
[Pointwise] cannot set "fan" boundary condition to 2D Ducted fan model brksnn Pointwise & Gridgen 1 January 11, 2013 09:05
Air flow simulation in volume with fan and opening koziymf FLUENT 0 November 14, 2011 17:44
Temperature rise at a boundry condition Rodrigo FLUENT 5 August 3, 2001 10:04
