Partition method "Metis" is not allowed warning in fluent |
November 24, 2014, 13:38 |
Rep Power: 11 |
hi everyones
after meshing my geometry when I open the file in fluent below warning is shownig to me how can i solve it ? Warning: Partition method "Metis" is not allowed for autopartitioning for cases with nonconformal interfaces before the interfaces are defined and intersected, use "Principal Axes" instead. You may use the "Metis" partition method after the case is read in and the interfaces are intersected., distributing mesh parts..., faces..., nodes..., cells..., materials, interface, domains, zones, bonded_-_looleh_to_ab-trg bonded_-_looleh_to_ab-src bonded_-_khak_to_grout-trg bonded_-_khak_to_grout-src bonded_-_grout_to_looleh-trg bonded_-_grout_to_looleh-src tagharon-grout tagharon-ab tagharon-looleh tagharon-khak share_khak outlet inlet grout ab looleh khak interior-grout interior-ab interior-looleh interior-khak wall-grout wall-looleh wall-khak interior-13 wall-27 wall-28 interior-29 wall-30 wall-31 interior-32 wall-33 wall-34 mesh interfaces, Note: Slitting sliding interface zone 32 into a coupled wall. creating wall-32-shadow parallel, Done. thanks |
November 29, 2014, 10:41 |
Rep Power: 11 |
no one knows ?
November 29, 2014, 13:06 |
Rep Power: 17 |
You need to create conformal mesh. To do so, create group of all parts in DesignModeler. And re-mesh. Most probably it will solve your problem.
December 1, 2014, 04:23 |
Rep Power: 11 |
January 12, 2022, 09:26 |
Same problem
Omkar Mogare
Rep Power: 4 |
I am also encountering the same problem. I'm doing an analysis of 3D Darrieus VAWT. I have only two parts, ie rotating domain inner and stationary outer domain.
[Other] mesh airfoil NACA0012 | anand_30 | OpenFOAM Meshing & Mesh Conversion | 13 | March 7, 2022 17:22 |
[CGNS] CGNS converters available | mbeaudoin | OpenFOAM Meshing & Mesh Conversion | 137 | December 14, 2018 04:20 |
OpenFOAM Solaris | mamaly60 | OpenFOAM Installation | 13 | May 10, 2010 21:16 |
Version 15 on Mac OS X | gschaider | OpenFOAM Installation | 113 | December 2, 2009 10:23 |
Warning 097- | AB | Siemens | 6 | November 15, 2004 04:41 |
