how to find heat flux from constant temp. B.C.
Old   November 29, 2014, 09:46
Default how to find heat flux from constant temp. B.C.
Ice man's Avatar
ayden
Ice man is on a distinguished road
I was simulating finned tube heat exchanger shown in figure below.
constant temperature boundary condition used in the inner surface of tube. I'll use this relation to calculate (h), [q=h*A*(Tw-Tref)]
How to find heat flux (q)
thanks
Ice man is offline   Reply With Quote
Old   December 1, 2014, 07:54
Ice man's Avatar
ayden
Is there another method please ?
Old   December 1, 2014, 08:33
pakk will become famous soon enough
Yes there is another way. You now do a volume integral, but it is better to do a surface integral, see number 2 in your plot.
pakk is offline   Reply With Quote
Old   December 1, 2014, 09:38
Ice man's Avatar
ayden
I know that, is there another method except Report> > volume or surface > wall flux >
Old   December 1, 2014, 09:47
You can write a UDF (define_on_demand) to calculate the heat flux.
You can output the results to ensight case gold, and use Paraview to calculate the heat flux.
You can save the result in ASCII format, put all in Excel and calculate it.
How many more ways do you want? Why are you asking for more ways to do the same?
Old   December 1, 2014, 10:52
Ice man's Avatar
ayden
because I've got unbelievable results .
Old   December 1, 2014, 11:30
So you were hoping that a different method to calculate the same quantity would give different results? And after that you were planning to choose the result that would suit you best?
If I were you, I would investigate why your method gave an unexpected result.
Old   December 8, 2014, 12:27
Ice man's Avatar
ayden
Mr. pakk
If you have a time come in ,please !
http://www.cfd-online.com/Forums/flu...tml#post522993
Old   June 5, 2015, 04:56
Default i have a question
DENG Weriping
wpdeng is on a distinguished road
what is the function of xyplot-wall flux-total surface heat flux?
if i want to get the heat flux along the line of walls, is this way right?
wpdeng is offline   Reply With Quote
constant heat flux imani OpenFOAM Pre-Processing 1 August 2, 2014 12:53
Constant Heat Flux Boundary Condition on Long Thin Pipe CGramlich SU2 3 April 22, 2013 08:25
Constant heat flux with uniform temperature Jake Lee FLUENT 2 April 13, 2011 22:08
constant Heat flux at the wall hatta FLUENT 2 January 9, 2004 07:13
Constant wall heat flux with uniform temperature Jake FLUENT 2 September 29, 2003 11:34
