Spalart-Almaras wall function
Old   December 9, 2014, 08:35
Default Spalart-Almaras wall function
Federico
fede_freefly is on a distinguished road
Hi guys,
I'm studying a flow over an airfoil characterized by 10^6 Reynolds value.
I'd like to ask you something about the Spalart-Almaras model, because I' ve red on the Guide that in FLUENT this model works with an Enhanced wall treatment. If I understood well, this treatment allows you to make a less dense mesh, with a Yplus value higher than 30, modelling in a certain way the viscous and the buffer layers.
Is it correct?
I've made a mesh with a Yplus of 65, cause i need a not so heavy mesh. Could the model work good for this kind of mesh?
Thanks !
fede_freefly is offline   Reply With Quote
Old   December 11, 2014, 10:06
B_Kia
HyperNova is on a distinguished road
This model works automatically, so based on your y-plus the model works good, for this model y-plus should be under 1 or more than 30 , if y-plus<1 then the enhanced wall treatment will be activated and if y-plus>30 the standard wall function will be activated automatically.
good luck
HyperNova is offline   Reply With Quote
Old   December 12, 2014, 15:40
Federico
good luck
Thanks for the answer !
Ok, i've done some simulation with this condition, is it good to apply the ADAPT function on the Yplus, imposing the max value allowed around 3 ?
Do you think the Spalart Almaras would give better results with this correction? or is it unnecessary?
(I' ve done both the simulation with and without the correction, but it seems to give pretty same value of Cl)
Old   December 12, 2014, 18:17
Federico
Ok, i should correct myself, i'm having a convergence problem with angle of attack at 10° with the non adapted mesh, still haven't done the tries with an adapted one.
Old   December 13, 2014, 08:51
B_Kia
hi,
if you want SA model workes as a low reynolds number y-plus around 1 is better, but i think 3 is also ok, good luck
foamToTecplot360 thomasduerr OpenFOAM Post-Processing 121 June 11, 2021 10:05
Enhanced Wall Treatment paduchev FLUENT 24 January 8, 2018 11:55
[blockMesh] Errors during blockMesh meshing Madeleine P. Vincent OpenFOAM Meshing & Mesh Conversion 51 May 30, 2016 10:51
Radiation interface hinca CFX 15 January 26, 2014 17:11
is internalField(U) equivalent to zeroGradient? immortality OpenFOAM Running, Solving & CFD 7 March 29, 2013 01:27
