What wrong: 2d axisymetric orifice nozzle cavitation |
January 15, 2015, 22:46 |
Anh
Rep Power: 11 |
124.pngHi, I am doing simple cavitation simulation in the orifice nozzle by using the model of Nurick which is similar to fluent cavitation tutorial. so I used the axisymmetric for this calculation. But the results are very different to Nurick's experiment. I also tried to run same condition with fluent tutorial file. The result is also different. Fluent report the volume flow rate is about 0.36m3/s which true result is about 10e-5m3/s. The flies below are the geometry grid, calculation condition and model grid. You also can find in the paper: "Mathematical Basis and Validation of the Full Cavitation Model" of Singhal (The geometry are outlet: d=8mm, inlet D=2.88d, nozzle length L=5d.) Do you have same problem? How to fix this problem? many thank! |
January 15, 2015, 23:07 |
Anh
Rep Power: 11 |
ghost82,
I saw you have experience about cavitation. Could you give comment? |
January 16, 2015, 11:25 |
Rick
Rep Power: 26 |
Hi Anh,
your problem should be related to boundary conditions and/or solution convergence. I tried to run a simulation with steam/water properties at 20 degrees, 500000 Pa inlet pressure and 95000 Pa outlet pressure (absolute) and I obtained a flow near 0.99 kg/s, which in my experience is correct. Flow rates depend obviously on pressure inlet/outlet. I saw that you have at inlet 2 velocity inlet boundary conditions: what velocity did you set? I suggest to change the inlet bc to pressure inlet. With 500000 Pa inlet pressure I have a mean velocity at inlet near 2.4 m/s. Remember to set properties of vapor at a pressure equal to the vapor pressure at the operative temperature (for example, if you have water flowing at 20 degrees, then vapor pressure will be 2340 Pa (absolute) and corresponding density will be 0.017 kg/m3). I suggest also to use the coupled scheme. Daniele
Google is your friend and the same for the search button! |
January 17, 2015, 03:16 |
Anh
Rep Power: 11 |
Thank you very much for your suggestion, ghost82.
I solved my problem. |
Convergent-Divergent Nozzle with MATLAB | Obad | Main CFD Forum | 8 | June 2, 2020 14:10 |
Nozzle two phases flow (cavitation model) | lehoanganh07 | Fluent Multiphase | 1 | May 16, 2017 04:50 |
udf error | srihari | FLUENT | 1 | October 31, 2016 14:18 |
Cavitation inception problem | newuser | FLUENT | 3 | May 13, 2003 11:14 |
Orifice Flow | Prateep Chatterjee | FLUENT | 4 | February 23, 2001 14:59 |
