Dynamic meshing of self-acting seat valve, how to control mesh event times?
Old   June 26, 2012, 03:21
Default Dynamic meshing of self-acting seat valve, how to control mesh event times?
DanielBeck is on a distinguished road
Hello out there! Thank you for a great forum, I have already learned a lot by reading old threads in here. However I'm facing a problem which i cannot seem to find an answer to, so here goes my first post :
I would like to model a reciprocating cylinder chamber, connected to a self-acting poppet valve.
To "close" and "open" the valve orifice for fluid flow, my initial try (found a description of a similar problem in the user guide) is to use sliding interfaces which is enabled/disabled at appropriate times when the valve are nearly closed. However, as the valve is self-acting (movement controlled by fluid forces), I do not a priori know the time where these sliding interfaces should be modified. I can modify the interfaces if I know the modification times, but this will depend on the simulation itself...
Is there some way to control these events using UDF? – or can you suggest some other method for opening and closing the poppet valve gap?
Please see attached pictures for mesh topology and wanted movement of the mesh..
Thank you in advance!
- Daniel Beck
DanielBeck is offline   Reply With Quote
Old   February 17, 2015, 12:36
Default self acting valve
kiru
milkha is on a distinguished road
Dear DanielBeck,
I also have same problem.In my geometry self-acting valve is there.If you have got solution for your problem of,how to specify user defined time for dynamic mesh events.
OR
How to hook UDF for user defined dynamic mesh event time?
please help.Its very urgent.
milkha is offline   Reply With Quote
Gambit problems Althea FLUENT 22 January 4, 2017 03:19
Dynamic mesh is not getting updated. cardio FLUENT 1 May 20, 2014 08:41
Dynamic mesh update problem. David FLUENT 3 March 15, 2012 05:02
Icemcfd 11: Loss of mesh from surface mesh option? Joe CFX 2 March 26, 2007 18:10
How to control Minximum mesh space? hung FLUENT 7 April 18, 2005 09:38
