March 31, 2015, 04:48 |
Setting Initial Temperature of Fluid
Keith
Hi, thanks for taking the time to read this.
I am trying to simulate natural convection in a cylinder, where the cylinder is fluid filled with water at 5C, and the outer surface of the cylinder is at a constant temperature of 40C. I have read and watched countless tutorials, but all of them do not show how to set the initial temperature of a fluid body. I can set the wall temperature using boundary conditions, but how do I go about setting the 'starting' temperature of the water? I'm not sure if I am clear, and I do apologise in advance if this is a very basic question. It's just that I have been searching for a solution for the past week already, and I am getting a little frustrated! Thanks, Keith |
March 31, 2015, 05:53 |
Rep Power: 18 |
Patch your fluid zone with a single temperature value via Solution Initialisation > Patch...
transsonic nozzle with rhoSimpleFoam | Unseen | OpenFOAM Running, Solving & CFD | 8 | July 1, 2022 06:54 |
should Courant number always be kept below 1? | wc34071209 | OpenFOAM Running, Solving & CFD | 16 | March 9, 2014 19:31 |
rhoSimplecFoam Mach0.8 no pressure values | CFDnewbie147 | OpenFOAM Running, Solving & CFD | 16 | November 23, 2013 05:58 |
Micro Scale Pore, icoFoam | gooya_kabir | OpenFOAM Running, Solving & CFD | 2 | November 2, 2013 13:58 |
Upgraded from Karmic Koala 9.10 to Lucid Lynx10.04.3 | bookie56 | OpenFOAM Installation | 8 | August 13, 2011 04:03 |
