How can i get velocity value on fluent ?
Like Tree5Likes
  • 1 Post By `e`
  • 1 Post By CeesH
  • 1 Post By CeesH
  • 1 Post By CeesH
  • 1 Post By CeesH
Old   April 8, 2015, 17:33
Default How can i get velocity value on fluent ?
Falcon35 is on a distinguished road
How can i get velocity values on a flat plate ? Example; i want to calculate velocity value at L/2 location of a flat plate ?
Falcon35 is offline   Reply With Quote
Old   April 8, 2015, 18:44
`e`
`e` is on a distinguished road
Within Fluent: Display > Plots...
Otherwise, using CFD-Post might be easier if you have the license. Create a point (2-D case) or a line (3-D case) location at x=L/2 and create a chart of the velocity in this new location.
Falcon35 likes this.
`e` is offline   Reply With Quote
Old   April 9, 2015, 03:24
How can i do it by using line/rake ?
Old   April 9, 2015, 03:29
Cees Haringa
CeesH is on a distinguished road
go to the plot menu as 'e' mentioned. There, you will need to select a location for the plot; you can make a line/rake and select it there.
Then set the appropriate x and y values (you can use curve length for the x-axis if you want to measure along the line), and you're good to go!
If you want to export the plot, tick 'write to file'. The values will be printed in a text file, which you can load in excel, matlab or another program of choice to make a nicer graph that FLUENT can do.
CeesH is offline   Reply With Quote
Old   April 9, 2015, 03:39
Bro thank you but can you describe it like this, surface> line/rake , create a vertical line at x = L/2 , then do it to calculate horizontal velocity value at that location. I need this please?
Old   April 9, 2015, 03:45
Cees Haringa
Go to surface > line/rake > set the coordinates of the start and end point of your line, give the line a name and create it.
Now go to plot > x-y plot. Under surfaces (bottom right), select the line you created. As y-axis function, set the velocity (or other parameter you want to check). For x-axis function, choose curve-length
Old   April 9, 2015, 03:50
Why y-axis set to velocity? I want to calculate horizontal velocity at L/2 and calculate boundary layer thickness
Old   April 9, 2015, 04:04
Please help me ...
Old   April 9, 2015, 04:09
Cees Haringa
You can plot the horizontal velocity at the vertical line you made.
In that case, as a y-axis function, set x-velocity. (you can also swap the axis if you want; in that case, set the y-axis function as mesh > y, and the x-axis function as x-velocity)
Old   April 9, 2015, 04:15
will i read L/2 velocity in writed file ?
Old   April 9, 2015, 04:26
Cees Haringa
Only if there is a nodal point at L/2. Otherwise you will have to interpolate between the closest points, or take the closes node value to L/2. If you have the CFD-post license, as 'e' mentioned, it may be more convenient to do it in there. In CFD-post you have an automated interpolation option as well.
Old   April 9, 2015, 04:43
Then how can i obtain boundary layer thickness change due to location L/4 , L/2 ,3L/4 and L ?
Old   April 9, 2015, 04:50
Cees Haringa
Ok, now I have a better idea of what you want - that was unclear to me first.
If you make a vertical line at x = L/2, yes, the values of x-velocity at L/2 will be exactly given, over the y-position in the boundary layer.
If you want to have the values at other values of x, also set up a line at those positions, and repeat the plotting there. Make a plot for x-velocity vs y-position at every x you want.
Old   April 9, 2015, 05:02
Bro, can you help me by teamviewer later to obtain boundary layer thickness change due to location of L?
Old   April 9, 2015, 05:41
Cees Haringa
Sorry, don't have time for that. But I think if you follow the steps, everything should work out fine.
Old   April 9, 2015, 06:35
Thank you then
looking for a smart interface matlab fluent chary FLUENT 24 June 18, 2021 09:07
Problem in using parallel process in fluent 14 Tleja FLUENT 3 September 13, 2013 10:54
some questions about fluent export velocity from ASCII? edongliang Main CFD Forum 0 May 3, 2011 22:22
Specifying a velocity profile in Fluent Edward Sayce FLUENT 1 November 28, 2006 19:13
User defined rotational velocity in FLUENT Abhinav FLUENT 1 June 10, 2003 08:31
