problems setting up heat transfer between plates - what is wrong with this?
Old   May 10, 2015, 16:33
Default problems setting up heat transfer between plates - what is wrong with this?
cglr
wales is on a distinguished road
I have two parallel plates and 40 mm distance between them. Air blows at two sides(left and right) of this gap. Plates have higher temperature than the initial air temp. I utilized kw-sst model with boussinesq. I need to observe heat transfer coefficient between air and plates in the end. But strangely when postprocessing, I see heat transfer coefficient contours for a plate in one color(third attachment). what is wrong about it ?
note: second attachment shows velocity vectors for middle plane. (y+ is 3,4)
wales is offline   Reply With Quote
Radiation heat transfer boundary condition natrask OpenFOAM Programming & Development 0 February 8, 2015 09:05
Error finding variable "THERMX" sunilpatil CFX 8 April 26, 2013 07:00
Heat Transfer Between two Plates neilth CFX 1 July 10, 2011 06:34
Setting data for heat transfer coefficient Miguel CFX 2 January 8, 2009 16:00
heat transfer in conjugate heat problems cirilo Siemens 1 April 18, 2006 09:16
