Volume fraction of dispersed phase to determine DPM, VOF, Mixture model
Like Tree2Likes
  • 1 Post By Amir
  • 1 Post By mtr94m
Old   July 19, 2011, 02:30
Default Volume fraction of dispersed phase to determine DPM, VOF, Mixture model
Mohsin Mukhtar
Mohsin is on a distinguished road
Hello
For using DPM model in fluent, volume fraction of disperesed phase should be below 10% to 12 %, otherwise you have to look for other models such as mixture and VOF models in fluent.
For determining Volume fraction of a particle, the following formula is used:
alpha=NpVp/Vc
where alpha= volume fraction of solid phase
Np=Number of particles
Vp=Volume of particle
Vc= Volume of the container or total volume of the cylinder or the whole control volume.
If alpha comes out to be greater than 12% then "mixture" or "VOF model" would be considered for dense phase.
Please comment if the above statements are correct/wrong.
Thank you so much.
Mohsin
Mohsin is offline   Reply With Quote
Old   July 19, 2011, 03:29
Amir's Avatar
Amir
Amir is on a distinguished road
The whole idea is right but some other points should be noted:
- Actually this range is not very tight; it's just a rule of thumb, I believe that if Lagrangian modeling could be proper for a case we can use it.
- Note that DPM modeling in FLUENT encounter many bugs in brownian motion and computing deposition, so in many cases in which diffusion term is dominant in dispersion; such as nano-particles, we have to use eulerian modeling, i.e. solving a transport eq. to find particle concentration.
Amir
pasargad64 likes this.
Amir is offline   Reply With Quote
Old   July 19, 2011, 03:46
Mohsin Mukhtar
Well, Amir, thank you very much for the guidance. Added to ur reputation
Old   January 30, 2015, 12:47
Kanarya is on a distinguished road
Hi Amir,
I am simulating gas-solid flow with two fluid approach with fluent and I am trying to have 20% mass loading of the particle at the inlet.
as it is same inlet for both phases area is not important...
my air density is 1.2 kg/m3, velocity is 9.3 m/s.
solid density is 2500 kg/m3 , I think velocity must be calculated but I am not sure or I can use 9.3 for solid as well?
how I can calculate the uniform volume fraction of the solid at inlet while assuming constant particle to gas velocity ratio?
do you have any idea?
thanks in advance!
Kanarya is offline   Reply With Quote
Old   June 7, 2016, 02:52
Default how to define volume fraction in dpm
mohammad
mtr94m is on a distinguished road
i have slurry jet (water and sediment).i cant define volume fraction for this problem.i define injection from surface.....
AHF likes this.
mtr94m is offline   Reply With Quote
Old   March 5, 2018, 07:47
NITIN
kattulanitin is on a distinguished road
Hello Mohsin,
How can we calculate?
Np=Number of particles,
Even if we calculate the number of particles by assuming a volume fraction how to input them in fluent?
Thanks and regards,
Nitin K
kattulanitin is offline   Reply With Quote
Error message: Insufficient Catalogue Size Paresh Jain CFX 32 February 3, 2021 03:37
VOF for single phase? vuccj7 FLUENT 0 April 20, 2011 19:59
two Phase column simulation chemeng OpenFOAM 3 August 18, 2010 12:53
Mixture model with one compressible fluid phase oden FLUENT 0 September 26, 2006 09:11
compressible two phase flow in CFX4.4 youngan CFX 0 July 1, 2003 23:32
