how to find heat flux from constant temp. B.C. |
November 29, 2014, 09:46 |
ayden
Rep Power: 11 |
I was simulating finned tube heat exchanger shown in figure below.
constant temperature boundary condition used in the inner surface of tube. I'll use this relation to calculate (h), [q=h*A*(Tw-Tref)] How to find heat flux (q) thanks |
December 1, 2014, 07:54 |
ayden
Rep Power: 11 |
Is there another method please ?
December 1, 2014, 08:33 |
Rep Power: 26 |
Yes there is another way. You now do a volume integral, but it is better to do a surface integral, see number 2 in your plot.
December 1, 2014, 09:38 |
ayden
Rep Power: 11 |
I know that, is there another method except Report> > volume or surface > wall flux >
December 1, 2014, 09:47 |
Rep Power: 26 |
You can write a UDF (define_on_demand) to calculate the heat flux.
You can output the results to ensight case gold, and use Paraview to calculate the heat flux. You can save the result in ASCII format, put all in Excel and calculate it. How many more ways do you want? Why are you asking for more ways to do the same? |
December 1, 2014, 10:52 |
ayden
Rep Power: 11 |
because I've got unbelievable results .
December 1, 2014, 11:30 |
Rep Power: 26 |
So you were hoping that a different method to calculate the same quantity would give different results? And after that you were planning to choose the result that would suit you best?
If I were you, I would investigate why your method gave an unexpected result. |
December 8, 2014, 12:27 |
ayden
Rep Power: 11 |
June 5, 2015, 04:56 |
i have a question
#9 |
DENG Weriping
Rep Power: 10 |
constant heat flux | imani | OpenFOAM Pre-Processing | 1 | August 2, 2014 12:53 |
Constant Heat Flux Boundary Condition on Long Thin Pipe | CGramlich | SU2 | 3 | April 22, 2013 08:25 |
Constant heat flux with uniform temperature | Jake Lee | FLUENT | 2 | April 13, 2011 22:08 |
constant Heat flux at the wall | hatta | FLUENT | 2 | January 9, 2004 07:13 |
Constant wall heat flux with uniform temperature | Jake | FLUENT | 2 | September 29, 2003 11:34 |
