multiple exits
Old   June 14, 2015, 07:01
Post multiple exits
Piyush Aras
piyusharas is on a distinguished road
I have systemin which i have a system in which a tank in present having inlet of water from top through a pipe. there are 6 exit slits symmetrically located .
I have given inlet boundary condition as velocity inlet and given it a velocity of -0.5m/s and i want to calculate the mass flow in all the exits. So i have kept them pressure outlet . But in post processing i am getting mass flow in some as positive and some as negative which is not possible as all liquid will flow in direction of inlet only that is under influence of gravity.
please help me out.
piyusharas is offline   Reply With Quote
Old   June 15, 2015, 06:35
Anonymous
marauder is on a distinguished road
Please post an image to understand the problem better.
Between, did you activate Gravity, Buoyancy effects?
marauder is offline   Reply With Quote
Old   June 18, 2015, 03:16
Piyush Aras
yes i am considering the effect of gravity .
here are some pictures of my model
https://drive.google.com/file/d/0B9c...ew?usp=sharing
Old   June 18, 2015, 04:40
liusuanyatong
liusuanyatong is on a distinguished road
I think your inlet velocity has a problem.Your velocity inlet setting should be positive.If your velocity is negative,it does mean that fluid flow outside computational domain,not intside.I'm sorry my English is poor.I hope my answer will help you.
liusuanyatong is offline   Reply With Quote
Old   June 18, 2015, 04:42
Post
Piyush Aras
but as you can see my y direction is opposite direction to flow to inlet .
so shouldn't i put negative velocity only.
and yes in inlet my fluid is flowing inside the tank.
Old   June 19, 2015, 00:36
Thumbs up
Anonymous
You are getting negative flow at some exits because you have recirculation zones near these exits. This can be observed from vector plots.
You have not allowed the flow to fully develop at the exit. Try extending the exits outwards so that the recirculation zone is fully captured and the flow at outlet fully develops.
Or else if your goal is to remove these recirculation zone try keeping baffles near the exits to control the flow direction.
how to set periodic boundary conditions Ganesh FLUENT 15 November 18, 2020 06:09
multiple exits piyusharas FLUENT 0 June 2, 2015 04:40
[ICEM] Multiple edges asal ANSYS Meshing & Geometry 2 March 22, 2013 10:10
OpenFOAM static build on Cray XT5 asaijo OpenFOAM Installation 9 April 6, 2011 12:21
Flow region with multiple exits Dimitris CFX 4 December 1, 2008 08:49
