outlet boundary condition for compressible flow with no definite details |
July 12, 2015, 15:39 |
Lida
Rep Power: 11 |
hi
I want to simulate a gas pipeline. the gas flowing in the pipe is compressible and in the inlet of the pipe the flow decreases gradually during a certain period; and will shut off after some times.so all parameters are variant in the outlet and my goal is to study the changes in the outlet. I can't use outflow boundary condition, because the flow is compressible and I don't have any other definite parameters to use for outlet boundary condition. I have searched a lot but I didn't find a solution. so I will really be thankful if someone could help me with this problem. |
July 12, 2015, 18:37 |
Lucky
Rep Power: 66 |
Are you sure you cannot use a pressure outlet boundary condition? Otherwise your problem is ill-posed. How can you even know the flow is compressible if you don't know the back-pressure?
July 12, 2015, 19:51 |
Lida
Rep Power: 11 |
as outlet pressure changes according to the changes in inlet, I can't use pressure outlet and because the flow is a gas under high pressure and because of changes in inlet,there may be high velocity in some places the flow should be considered compressible, so that density changes could be taken account.
Could you please explain more about ill posed problems?It means that there is actually no solution in the fluent?what about other programs like CFX or sth like that? |
boundary condition at outlet for microchannel flow | josephmp | FLUENT | 5 | February 9, 2015 08:10 |
Outlet boundary condition 'preventing' back flow | Anna Tian | FLUENT | 1 | January 23, 2014 05:07 |
outlet boudary condition for a flow in the pipe | Atit | CFX | 2 | November 9, 2004 17:43 |
New topic on same subject - Flow around race car | Tudor Miron | CFX | 15 | April 2, 2004 06:18 |
Outlet boundary condition for pulsatile flow | Timite | FLUENT | 0 | January 22, 2003 03:56 |
