_999999: Unable to allocate storage._
Old   May 28, 2010, 10:55
Default _999999: Unable to allocate storage._
Ahmed Taha
ataha is on a distinguished road
I received the following problem with one of the Fluent users I am supporting on our Supercomputer. We have a shared memory big machine which has (1GB) per core. Any inputs?
We have constructed a very large size mesh (about 45M, in future
application, even bigger one will be needed) and have successfully been
imported into Fluent running our local Win64Xp workstation (32G RAM, 8
cores). Preliminary simulation has been running and worked OK, but one
iteration took about eight hours. Then we resorted to NCSA parallel
computers.
But the problem is when we submitted the task, the following error appear:
We have tried many methods, including :
(1) increase the node/core number;
(2) increase the parallel process of Fluent;
(3) change from Fluent6.3 to Fluent12;
(4) using -himem option;
Until now, the maximal node/process used is:
#PBS -l nodes=60pn=8:himem
Fluent121 3ddp -g -t48
But the grid can't be imported due to the error of "Unable to allocate
storage ".
ataha is offline   Reply With Quote
Old   August 21, 2015, 01:35
Tom
samy902 is on a distinguished road
Hi ataha,
I am going through a similar case. Did you find any solution?
samy902 is offline   Reply With Quote
Sun Grid Engine grtabor OpenFOAM Running, Solving & CFD 28 August 22, 2012 09:27
ERROR: Unable to allocate 45256392 bytes of dynamic memory. eespi002 ANSYS Meshing & Geometry 15 October 27, 2010 13:38
openfoam 1.6 on debian etch romant OpenFOAM Installation 9 May 6, 2010 02:26
[Commercial meshers] ST_Malloc: out of memory.malloc_storage: unable to malloc Velocity SA, cfdproject OpenFOAM Meshing & Mesh Conversion 0 April 14, 2009 15:45
Gambit unable to allocate dynamic memory Abhijeet Karnik FLUENT 0 October 2, 2006 12:59
