Coordinate systems and Boundary Profiles
Old   August 16, 2015, 12:50
Default Coordinate systems and Boundary Profiles
Christian Mahr
chri is on a distinguished road
Hi guys,
I've started to use FLUENT a couple of months ago and as I am trying to set up a model referring to a technical application. Due to it's accuracy of simulation it should include single phase flow (air) using 30 inlets, each inlet using a inlet-velocity profile.
As described in the user's guide, I defined profile, using the format including x,y,z coordinates and velocity vectors. This worked out fine and when I got it right, reorientating the profile calculates the vectors, so they have the same orientation, referring to the new inlet, right?
So what I don't get, but what would be really helpful is the use of the cylindrical and the local cylindrical coordinate system.
What I know, is how a cylindrical coordinate system is defined, but defining a profile xyz-coordinates are asked for the points where I want to define velocities?!!
Besides that, when defining a local cylindrical coord system, what is meant by orientation vectors in xyz-directions?! I would be extremely thankful for help on this case, as I've been struggeling with it for quite a while!
All the best,
Christian
chri is offline   Reply With Quote
FLUENT Periodic Boundary Condition SOLVED + TUTORIAL Peter023 FLUENT 55 July 11, 2020 06:40
Non reflecting boundary condition Saeid Main CFD Forum 9 April 13, 2014 13:29
Wall coordinates and boundary layer thickness bentmol Main CFD Forum 1 July 3, 2011 20:44
Boundary Conditions Jan Ramboer Main CFD Forum 11 August 16, 1999 08:59
[Q] Boundary conditions in Turbomachinery ghlee Main CFD Forum 3 July 23, 1999 17:05
