How to set a initial temperature and constant heat flux at same BC's?? |
May 25, 2009, 03:07 |
Jane
Rep Power: 17 |
i have set the wall boundary condition with heat flux w/m2 and i want to set the initial temperature for the same wall.
in my cooling simulation, the initial temperature of wall will decrease and the wall is depend on the heat flux. however,for the boundary condition setting for wall, the thermal condition "temperature" is only can be set to constant. when i set it as a constant, my wall bc's just display a constant temperature in the result. when i set the temperature at the wall in "initialize > compute from > wall". the result still show the similar temperature for my wall boundary conditions. Please give me any idea to solve the problem. Thank you |
March 20, 2010, 08:36 |
How to set constant heat flux BC as well as initial temp
GS Gunasegarane
Hi Jane
Did you get any reply for your query on heat flux BC. I am also having the same problem of setting constant flux BC for a wall as well as the wall initial temperature. Since the temperature is set as constant in the BC it is showing constant temperature in the result. If i set it to zero, it is showing zero temp close to the wall. But I would like the wall to change the temperature as per the heat flux condition. If you have solved your case then pl help me out. If somebody have an idea how to overcome this problem pl do guide me. Thanks in advance |
April 16, 2013, 09:03 |
Cristiano
Rep Power: 13 |
have you ever been solve the case? I've your some problem... |
October 21, 2015, 04:49 |
Variable temperature
giuseppe lombardo
Rep Power: 11 |
Does anyone know how to solve this problem? I need to put a variable temperature as boundary conditions, but I don't know hot to do it. I think that could be done by defining a UDF. Please somebody help me!
October 25, 2015, 12:01 |
Lucky
Rep Power: 66 |
Do not confuse initial conditions with boundary conditions.
If you want to set an initial temperature profile with a constant heat flux boundary condition: The initial conditions are handled in the solution initialization procedure. You do not apply initial conditions as a boundary condition. If you need to specify a temperature profile as the initial condition then you should define a field function and patch that to the wall. Or you can use a fancy UDF. The boundary condition should be the constant heat flux. |
Calculation of the Governing Equations | Mihail | CFX | 7 | September 7, 2014 06:27 |
Constant heat flux with uniform temperature | Jake Lee | FLUENT | 2 | April 13, 2011 22:08 |
Two-Phase Buoyant Flow Issue | Miguel Baritto | CFX | 4 | August 31, 2006 12:02 |
heat transfer with constant wall temperature | Marco | FLUENT | 0 | December 8, 2005 07:16 |
Constant wall heat flux with uniform temperature | Jake | FLUENT | 2 | September 29, 2003 11:34 |
