December 5, 2015, 13:51 |
transnational periodic boundary
faisal shafiq
i am simulating flow over tube banks and i am wondering how to patch a velocity profile obtain from another simulation at the inlet of current simulation where you define the inlet as periodic boundary condition?
December 7, 2015, 15:26 |
Lucky
Rep Power: 66 |
Which simulation is periodic? The previous one or the new one? I'm guessing the new one?
You cannot specify velocity profile at a periodic boundary condition, which would be redundant. You should just run the simulation with the periodic boundaries, you can initialize the simulation with the other velocity profile if you want but you cannot specify periodic boundary condition and velocity profile at the same time (at least not easily). You can trick it by using a bunch of interfaces, but there are only limited number of reasons for ever needing to do this. |
Periodic boundary conditions | happy5jump | FLUENT | 6 | May 3, 2017 00:36 |
Waterwheel shaped turbine inside a pipe simulation problem | mshahed91 | CFX | 3 | January 10, 2015 11:19 |
Difficulty In Setting Boundary Conditions | Moinul Haque | CFX | 4 | November 25, 2014 17:30 |
Symmetry and Periodic boundary conditions | CFD_Fluent_User | FLUENT | 1 | October 16, 2014 02:18 |
Low Mixing time Problem | Mavier | CFX | 5 | April 29, 2013 00:00 |
