What is the difference between pore diameter and particle diameter in porous media?
Old   January 9, 2016, 07:49
Default What is the difference between pore diameter and particle diameter in porous media?
Emara is on a distinguished road
I am modelling metal foam in fluent (Porous model) and I need to know the difference between pore diameter and particle diameter in porous media? And the difference between porosity and particle per inch designation and how to find the other when I have only one?
Thanks in advance
Emara is offline   Reply With Quote
Old   January 10, 2016, 06:30
Default Fluent for Porous Media
Ray
Rayman is on a distinguished road
Hi Emara
Sorry, I am like you new here and in Fluent. But, as you are working with CFD in porous media, I just thought maybe I can ask you a question: how and where did u put porosity in fluent? How about cylindrical flow direction (do you know how we can consider that)? Thanks.
Rayman is offline   Reply With Quote
Old   January 10, 2016, 10:42
Hello Rayman,
Once you defined your porous zone in "Cell Zone Conditions", you can click "Edit" and then a window will appear, you shall check "Porous Zone" and under the "Porous Zone" tab you shall find "porosity" at the bottom of the window.
Old   January 10, 2016, 10:45
Default fluent porous
Ray
Thanks Emara, yes I know but i think that is fluid porosity and should be 1 always. Am i wrong?
Old   January 10, 2016, 10:51
No, it shouldn't. That's the value of your region's porosity (epsilon in the averaged governing equations). The "1.0" value means all fluid and 0 means all solid.
Old   January 10, 2016, 10:55
Default fluent
Ray
Dear Emara! Thanks. Do u know how to make a profile? Maybe we can be connected for easier discussion on cfd by email if u dont mind: rahman.ashena.313@gmail.com. I really appreciate it.
Old   January 10, 2016, 11:01
Sure, check your private messages inbox.
UDF for particle interception with pt_termination fortran routine abcdefgh CFX 6 October 6, 2019 13:30
local thermal non equilibrium model in porous media adi.ptb Fluent UDF and Scheme Programming 0 November 1, 2014 15:00
where to input the particle or fiber diameter D with Porous Media Models digoy FLOW-3D 0 October 17, 2013 22:38
Check particle impaction with User Fortran Julian K. CFX 3 January 12, 2012 09:46
Iclude particle diameter effect in wall? yueroo FLUENT 0 April 14, 2001 03:56
